Just be careful with that 650 bucket. I trashed mine a while back and found that the 650 bucket I first got didnt have enough room behind the headlight to accomodate the wiring harness. The OEM 1100 bucket on mine has a more bulbous rear end for the wiring to fit into, whereas the 650 one i got was just a spherical shape with no extra room. I found an OEM on ebay and with the help of another member, got it sent out here. It will fit up okay but you may have to really jam the wiring in to close it up.
a couple newbie questions....
Originally posted by b.walker5 View PostJust be careful with that 650 bucket. I trashed mine a while back and found that the 650 bucket I first got didnt have enough room behind the headlight to accomodate the wiring harness. The OEM 1100 bucket on mine has a more bulbous rear end for the wiring to fit into, whereas the 650 one i got was just a spherical shape with no extra room. I found an OEM on ebay and with the help of another member, got it sent out here. It will fit up okay but you may have to really jam the wiring in to close it up.Fast, Cheap, Reliable... Pick any two
Perhaps I was wrong, I thought the XS650 bucket was a 100% match to the 1100 bucket.
Anyway, you can use bolts to mount the bucket, but the stock setup is that the turn signals have a bolt in them that goes through the brackets and into the headlight bucket and serve as the mounting bolts.
Turn signals
IIRC, that's what I used when I took the fairing off of Black Ice when I got it - a headlight bucket from a 650. It wasn't quite plug-and-play, but it was fairly easy to get working. The bucket bolts to the ears with the signal light stems. Make sure you grab a set of them, and the little bracket that bolts on under the bucket for setting the beam height.Ken Talbot
Originally posted by DGXSER View PostPerhaps I was wrong, I thought the XS650 bucket was a 100% match to the 1100 bucket.1980 SG. (Sold - waiting on replacement)
Originally posted by b.walker5 View PostYeah, that what I thought to, and was told that by others (not here) but it defininately didnt work that way in practice.The baskets show up on ebay for a few bucks often
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
