I picked up a set of guages for my bike because the ones on it were not functioning correctly. Once on, I learned that the backplate with the numbers on it is sticking out in such a manner that it stops the needle at 4k rpms. Has anyone dealt with this problem before?
Tachometer backplate sticking out
"There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
Active: 1932 Ford Model A; XS1100SF (Just got 'er); XS1100SG; 2000 F250 Turbo Diesel; 2003 Ford Mustang
Broken: 1999 Kawi Vulcan 750; 1998 Triumph Trophy 1200
Gonners: XS1100SF (my first ride); '82 Honda CB900F (bored to 1123cc); '86 Kawasaki ZG1000Tags: None -
Can you see both the small screws that hold the face plate on? Do they look loose? or is there one missing? Either way it sounds like you might have to dismantle the guage to fix it. Theres a tech tip here that explains the process, if you have to dig into it.
"A man should look for what is, and not for what he thinks should be" Albert Einstien. -
Actually it seems as if the screws are still secured to their mounts. Perhaps something else separated inside? Anyway I will attack this project very soon"There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
Gonners: XS1100SF (my first ride); '82 Honda CB900F (bored to 1123cc); '86 Kawasaki ZG1000Comment
STUPID!!!
I should have kept posting on this subject. Both the screws were in place and solid.
Well, I followed the tech tip, and when I got everything apart I found that the bolt holding the tach unit into the bucket had come loose (somehow) at the tach unit side of the assembly; and having been loosed, drove the unit out toward the glass.
If I had suspected this simply tightening the mount bolt would have pulled the entire thing back together and solved the problem.
Nonetheless, problem solved... I just need to get it back together now that my tach bezel is slightly misshapen ^_^"There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
