Clutch
Thread seamed to get off your needs, it happens. Sounds like you have a binding somewhere, most likely the cable, easy check. Lossen and disconect the cable from the clutch lever and see if it moves freely when pulled back by hand, if not, might try lubing the cable but if it is that tight, I would replace it. If the cable is free, you will need to check the clutch lever and through out bearing for binding and lub/replace as ness. I would replace the springs while at it, cheap fix, good luck
Originally posted by bdw72
View Post
