having trouble in the low rpms
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    this weekend i decided to take the judge out for its first interstate voyage (300 mile). well everything went good on the way there but as soon as i get close to the my final destination it starts to pop, backfire, wont alow my rev past 4-5 grand and sounds like the cylinders are cutting in and out. i fell like im on a harley cause i have to rev the hell out of it at every stop light and rev up way to high to start moving and then it starts popping backfiring and cylinders start to cut out.any suggestions
    1980 gs1000g "stock"
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Gas
    Sounds like you could be running out of gas, what happens on prime setting, do you have the octy still?
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      Check your P/U coil wires for breaks.
        Ditto.....
        • mack
          • 2411
          • Ontario, Canada
          when did it start
          Had this happen to me last week. Got some gas and rode about 10 miles and it started to do the same thing. Wound up having to drain the tank and carbs and put fresh gas in. Cleared right up.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • lee_dutcher
            • Apr 2009
            • 822
            • mason city iowa
            on the trip i always made 50mile ride before i stop and got gas which lefts me about half a tank. yes i still got my octy. i trimmed the coil wires about a 1/4". still doing the same thing...it seems likes its missing like crazy when im in low gear and the the cylinders are cutting in and out.
            • BigRed
              • Mar 2010
              • 265
              • Ottawa, Ontario, Canada
              Do you mean that you trimmed your spark-plug wires? The pick up coil wires are under the timing cover on the left side of the engine. They flex when the vacuum advance operates, and they're prone to breaking.
              • lee_dutcher
                • Apr 2009
                • 822
                • mason city iowa
                oh i havent checked that out yet but i do have the cover off...i wasnt sure what p/u ment...it makes alot of racket when operating... click click clicking
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  If it's making lots of noise at idle, make sure it's hose is hooked to the carb body and not the carb boot, as that will not only cause other performance problem, it will greatly increase the wear and tear on the pickup coil wires and increases the likelyhood of that being the problem.
                  Ok, to cover this again, there should NOT be any clacking coming from the advance system at idle, if there is, there is something wrong. If the vacuum advance it bouncing up and down (actual significant movement) at idle, that's BAD, check the hose for proper connection.
                  • lee_dutcher
                    • Apr 2009
                    • 822
                    • mason city iowa
                    where douse this hose go....mines on the second carb inner boot where the nipple is ( thats the way it was from po)..would this be causing my problems....
                      The hose form the vac advance that is under the timing cover should go up to the nipple on the carb body of the #2 carb. It is the only carb with a nipple on the body. It does NOT go to the nipple on the black rubber boot for #2 carb. That is only used for synchronizing the carbs, and for operating the Octy or the petcock on the standard models.
                      • cywelchjr
                        • 4450
                        • Sacramento, CA
                        +1 on the carb body. It seems we are seeing more and more people having that problem, with the vacuum advance hooked to the carb holder instead of the carb. Please check folks, you do NOT want direct manifold vacuum applied to the vacuum advance, only the ported vacuum from the port on the number 2 carb body. It probably won't damage the advance unit, but it's likely to break pickup wires and it will certainly make the engine run in a less than optimal fashion at lower RPM's because it will be bouncing between way too advanced and where it's suppose to be. I'm pretty sure that vacuum port on the carb never gets full manifold vacuum.
                        • lee_dutcher
                          • Apr 2009
                          • 822
                          • mason city iowa
                          can anyone snap a pic so i know exactly what and where the line CORRECTLY go....please and it is much apprecatiated...i need it running well so i can go to conesville iowa in septeber 3-7
                            Look at the picture in post #22, that is where the vacuum advance hose hooks up to on the #2 carb body.
                            • lee_dutcher
                              • Apr 2009
                              • 822
                              • mason city iowa
                              those carbs look completely differnt from mine. mine are slides not butterflys tomorrow after work ill take a look and post again...B)
