Front tire spin
  • TexinMaine
    • 160
    • Norway, maine
    Front tire spin
    I have noticed that the hadeling of my XS gets a little funny feeling sometimes. So yesterday I jaked up the front and tried to see is anything was loose. Every thing seemed tight, I grabbed the tire and moved it up, down sid to side and nothing seemed loose. However I gave the wheel a spin and it hardly made a full rotation. I checked the calipers and there is light visible on either side of the rotors so their not rubbing. So I am guessing maybe I need to regrease the axle perhaps? Any tips are appreciated.
    Tex
    1981 XS1100H
    Quando omni flunkus moritati
    When all else fails, play dead.
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    When is the last time you had the front wheel off? I suggest removing it and reinstalling it per the manual... how many miles are on it, maybe you need new bearings.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • TexinMaine
      • 160
      • Norway, maine
      I have never had the tire off, I just got it this spring. The speedo says 6700 miles, but it looks newer than the tach so it could have been replaced. I was wondering if there was a bearing or something in there. I do feel a vibration in the hanlebars at lower speed but when I give it throttle it dissapears. Thats why I originaly jacked it up to see if there was any play in the wheel. So the bearing could be bad abd yet still be tight?
      Tex
      1981 XS1100H
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        rotors
        (Oh boy, here goes, just can't wait to see who slams on this one) You have two disc's being contacted by 4 pads all the time, ever so lightly when breaks are not applied, but still contacting them. If everything turns smoothly and you don;t feel much resistance when you move by hand, you are prob fine. If you think the resistance is too high, check both side's of pads to see if one is more worn then the other, you might have a caliper piston hanging up
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          vibration
          Tex
          Sorry, my last post got sent before I read your new one. Can you tell me more about this vibration? Most bearings don't cause that till they are realy bad I would think your spin/shake test of the front wheel would have shown that kind of ware
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • TexinMaine
            • 160
            • Norway, maine
            Kind of hard to explain the vibration, it is sort of a feel and sound. I guess it is more of a grinding feel, thats why I was worried about it being the bearing. The drive also came to mind but I checked the middle and final and the levels were fine. So I guess a grinding would be a better description.
            Tex
            1981 XS1100H
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              Grinding
              If you are hearing a grinding and feeling it in the handel bars, def. remove the front wheel. I would replace both bearings, not much $ and you will be able to tell if the caplers are hanging as it will be hard to pull the rotors out if they are. Some gear noise is normal from drive train with some slack, lots of gears all hooking up from motor to wheel, but if your front bearings are grinding and you feel it in your hands, I would fix before riding again. If a front bearing locks up (not often) that could be bad
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                Yes, take the wheel off and check the bearings. Simply stick your finger into each bearing and turn it; if it's anything other than easy/smooth, it's toast.
                And while a seized front bearing would be very unlikely to stop the wheel, it will chew the crap out of your axle and/or wheel, so be aware...
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  bearing
                  that is correct, a locked up bearing most likely won't stop the wheel but it will tear up the axle and could ruin the wheel, also, a long walk home or ride in the truck + the whole thing could cause an wreck, be safe and good luck
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
