Let's see if the collective wisdom can figure this one out...
Finally got my new tires mounted on my freshly-polished rims, but the rear one insists on leaking around the bead. The sealing suface on the wheel is spotless, as I made sure that was thoroughly clean and free of gouges, nicks, etc. The tire mounted fairly easily, and the bead comes right up when putting air in. But it doesn't seem to want to come quite all the way up. I lubed it with some dish soap for the initial install, and have since tried various things (WD40, window cleaner) with no success. I've tried pressures of up to 60 PSI... no help.
What makes this particularly irritating is I purposely swapped to later tubeless rims to get rid of the tubes, so I don't want to put a tube in unless I absolutely have to. By the way, these are my first tubeless bike tires, as the '78 XS came stock with tubes and all my other bikes have laced wheels; I was hoping to have one bike that I didn't have to fight tubes on. I guess worst case, I can squeeze some silicon in there and do it that way, but I don't want to glue the tire to the wheel either
Any tricks or ideas?
