O Ring on bottom of jugs
    What is the point of that o ring on the bottom of the jugs? If I just them in and then use an anaerobic gasket maker instead of the real gasket will those o rings stay on or fall out onto the crank?
    The o-rings keep oil from wicking up between the cylinder sleeves and the aluminum cylinders or seeping out around the cylinder base gasket.
    If you use the o-rings they only need to be lightly compressed to seal and they won't fall out unless something went seriously wrong when the cylinders were put over the pistons into the upper engine case and the head bolted down.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Gasket
      This is a low pressure seal, unlike the head gasket, if you cut the gasket to OEM spec and use new o-rings, can buy many places, you should be fine
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        My thing is that I dont want to use a gasket there. It is such a PIA to get it off when you have to take it off. I want to know if those O rings can hold themselves in or if they need that little lip from the base gasket to hold them in.
        • CatatonicBug
          • 6117
          • Clinton, UT
          The base gasket can be replaced with RTV. I know a few folks here have done just that with no problems.
            • 8752
            Just be aware that leaving out the base gasket will increase your compression ratio and cause more slack in your cam chain.
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              I agree, if you dont want to spend the $ on a OEM gasket go buy a roll of gasket mat. and ink the bottom of the cyl for a pattern and cut out, but I would put a gasket back in there
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                • 8752
                Only the 30 year old ones are a PITA to remove. If you coat your new one on both sides with RTV, it should come off next time no problem, BTDT.
                • mxmikie
                  • Aug 2008
                  • 482
                  • Bouse az
                  send me your address and i will mail 4 new o-rings
                  careful what you wish for.........you might get it
                    Thanks for the offer I got them all in today and the jugs on!
                      Hehehe he said jugs!
