pffft.......you can't adjust fluid. There is ABSOLUTELY NO ADJUSTMENT on disc brakes.
The only thing that is adjustable is the pushrod in the MC and if you get it too tight it won't allow the lip of the cup to return past the spooge hole and the brakes will lock up.
I suppose you could do it with the pedal adjustment but you would have to be trying pretty hard.
