pffft.......you can't adjust fluid. There is ABSOLUTELY NO ADJUSTMENT on disc brakes.
The only thing that is adjustable is the pushrod in the MC and if you get it too tight it won't allow the lip of the cup to return past the spooge hole and the brakes will lock up.
I suppose you could do it with the pedal adjustment but you would have to be trying pretty hard.
, are you saying that the fluid "does not move back into the MC when the pistons are pushed back in (ie adjusting the fluid level in the MC to possably over filled)" Well, then how do the pistons move backward? I know the answer, I am just trying to get you to "think"
, that is the only way the pistons can be pushed back in
. pfft, "Even a fool is counted wise in his silence" this might help in the future
, just thought I was getting punched in the chin again for just trying to help
Even with dual brakes, the stopping power on these things is really weak. Get a MC that has a large enough bore to support 2 calipers (MikesXS sells a brand new OEM one) and protect yourself!
