1980 XS11SG
I have had a prevelent ticking sound under the timing cover since I purchased the bike at 7500mi. It diminshed somewhat (possibly my imagination) when I adjusted the timing chain. I just took the bike in to have the valves re-shimmed and when I got it back it was way louder. We removed the timing cover and I found the timing advance was rocking back and forth (aproximately in sync with engine revolution) and the sound was certainly coming from this. I removed the vacuum to the advancing motor and discovered a vacuum leak at the carb end of the hose. Having repaired the leak I still hear a loud ticking, mainly when I'm getting on it at low rpm's. It is not noticable at higher revs (or perhaps just can't be heard)
