Loud ticking sound under timing cover
  • Macamon
    • Aug 2009
    • 71
    • Los Angeles
    1980 XS11SG
    I have had a prevelent ticking sound under the timing cover since I purchased the bike at 7500mi. It diminshed somewhat (possibly my imagination) when I adjusted the timing chain. I just took the bike in to have the valves re-shimmed and when I got it back it was way louder. We removed the timing cover and I found the timing advance was rocking back and forth (aproximately in sync with engine revolution) and the sound was certainly coming from this. I removed the vacuum to the advancing motor and discovered a vacuum leak at the carb end of the hose. Having repaired the leak I still hear a loud ticking, mainly when I'm getting on it at low rpm's. It is not noticable at higher revs (or perhaps just can't be heard)
    "There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
    Active: 1932 Ford Model A; XS1100SF (Just got 'er); XS1100SG; 2000 F250 Turbo Diesel; 2003 Ford Mustang
    Broken: 1999 Kawi Vulcan 750; 1998 Triumph Trophy 1200
    Gonners: XS1100SF (my first ride); '82 Honda CB900F (bored to 1123cc); '86 Kawasaki ZG1000
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Originally posted by Macamon
    1980 XS11SG
    Was the line hooked to the port on the rubber carb mount or to the carb itself? If it's hooked to the rubber mount, that's the wrong place. It's supposed to go to the vacuum port on the number 2 carb, which should have little if any vacuum at idle, certainly not enough to be moving the advance assy significantly. It most certainly should not be jumping back and forth at idle though, that points to a problem.
      We removed the timing cover and I found the timing advance was rocking back and forth)
      Was the timing plate wobbling or the advance mech just rotating? If the plate was wobbling the the shaft that it bolts onto is not seated correctly. There is a little dowel that it sits on and if it is not sitting correctly on that dowel then your timing could be off.
      • Macamon
        • Aug 2009
        • 71
        • Los Angeles
        I will check the mount point for that vacuum line when I get home. That definately sounds like the problem.
        It was the timing advance assembly that was moving. There is only a slight "out of true" rotation of the disk at the end of the shaft 1/8"
          The Sound and the Fury...
          Macamon,
          Yeah... that noise had me concerned also. Even if everything is hooked up right and functioning perfectly it will sound like this:
          Camera is mounted less than 4 inches from that cover/assembly so the noise is really captured well.
          Keep looking and listening to your bike. You'll get familiar with the "normal" sounds and when something abnormal/wonky catches your attention be sure to stop and check it out.
          Or invest in a fairing with a loud 8-track stereo installed to drown out anything that would otherwise provide a clue as to the bike's running condition. No fair using an I-pod with ear-buds to drown out any/all road and engine noises...
          • nutwister
            Xsive
            • Jul 2010
            • 38
            • Planet Earth
            LMAO Larry, I believe you are right though. The rattling is the centrifugal advance mechanism I think. Mine does it at idle if it's idling too low.
            Mine idles at about 13 or 14 hundred. The higher idle seems to cure a lot of goofy low end problems too.
            • cywelchjr
              • 4450
              • Sacramento, CA
              While it will rattle at low speeds, you shouldn't get any noise from it or any significant movement at idle. If you do, something is wrong somewhere as the port it's supposed to go to is ported vacuum, meaning there is little if any vacuum at idle. If it's not hooked directly to the carb itself, then it's hooked up wrong.
              • Macamon
                • Aug 2009
                • 71
                • Los Angeles
                BINGO! The R-tard mechanic that worked on it forgot to reconnect the horns and got the fuel shutoff and vacuum advance swapped. Problem solved.... Now I'm getting a backfire :'0 During Warmup it backfires on the right side exhaust can, it pops with a ringing sound. When I turn off the choke the backfire goes away but she runs somewhat uneven and I still get some popping on shutdown.
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  • Fort Myers, Florida
                  R-tard
                  Is the R-tard mech that did the wrong vac hook up the same R-tard that adj your valves? If so, it could be one or more of your exaust valves is to tight. If they don't close well, un-burnt gas can leak into exaust, and cause backfire/poping
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                  • 79XS11F
                    • 3563
                    • Ottawa, Ont. Canada
                    If adding fuel (chock) removes the problem then you likely have an air leak somewhere in the intake track.
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • dbeardslee
                      • 4385
                      • Maineville, OH
                      Larry - did you notice that, when you put the kick stand down in the video, it made almost exactly the same noise? You sure it isn't the heat shields on the exhaust rattling? There are a couple little mounting brackets underneath the heat shield that are welded to the exhaust. If the weld's break the bolts may still feel tight, but it can make a heck of a noise. JAT
                        Heat Shield Bracket Racket???
                        dbeardslee,
                        I'll take a look at those brackets/welds today. Truthfully I've never looked at'em since I checked out the exhaust before installing it. Been a few miles since that happened....
                        Thanks for the second set of eyes and ears, dbeardslee. I figure that's one of the best parts about sharing and interacting here on channel 11. I mean if I (or anyone for that matter...) miss seeing/hearing something then I won't know that I missed it cause I didn't see/hear it, right?
                        Maybe there's a way for me to get a video of the P/U assembly "chattering" as I drive round. Hmmm...another Video project? A chance to use the new "Picture in Picture" feature?? (Gawd!! These bikes are so "camera friendly"...)
                        Thx...
