no muffler question
  • dezmitchell
    • Jun 2010
    • 51
    • vegrEVILle AB
    no muffler question
    K so my bike was running rich, it would get hot and just bog out and die .....My new (stock) jets came in today and i installed them, bike no longer richens out and dies but it seems to sputter at a constant throttle at any speed .....bike does not hesitate while acelerating but it back fires while off the trhottle and down shifting .....This bike has straight pipes on it (not by me by the previous owner) would installing mufflers solve my problem??
    1980 XS standard With Pods and Harley mufflers
  • raqumup
    • Feb 2004
    • 94
    • Ashburn, VA
    its hard to say but in most cases yes it should help because most engines need some back pressure to run properly. also stock jets are not right for straight pipes. i have pod air filters, accell coils (3 ohms) and wires, mac exaust, i am running 138 main jet, 42.5 pilot jet, 180 air pilot jet, needle is in the middle, and float hight is as close as i can get to 25.7mm, and about 2-2.5 turn out on the pilot screw. i don't know what the stock jet numbers are?
    79' XS1100SF
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      exaust
      I had mac 4 to 2 pipes when I bought my bike, poped and backfired bad! tuned, rebuolt carbs, helped some. Changed to OEM exaust, prob gone, runs great, no pop or backfire anymore. Everthing else has to be right, but the OEM exaust makes it all sing IMHO
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        I've never tried it, but more than a few pretty knowledgable folks have coe on here trying to figure out how to get these bikes to run decent with open exhaust. I do not know of any that succeeded without putting some kind of baffle in place.
        • MindWebs
          • May 2009
          • 431
          • Baldwin, WI
          It's a PITA...
          like everyone say's, these bikes need backpresure of some sort.
          this is what i did.
          How to make HD pipes work on a xs1100.doc
          i still had to bump to bigger jetting.
          my stock pilot jet is a 42.5, i'm running 45.0 (2.5 turns out on the needles)
          stock main is a 137.5, I'm thinking 2 higher would be about right.(142.5)
          BUT!!! that is for my setup.
          you may need to adjust from there.
          also see here: http://www.xs11.com/forum/showthread.php?t=382
          for jetting recomendations.
          good luck
          also georgefix(ebay) is the man to get jets from.
          very good to deal with and Very reasonable prices.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Cool
            Originally posted by MindWebs
            It's a PITA...
            this is what i did.
            good luck
            Cool, glad you got it to work that way. 2 1/2 turns on needles? Is that what just ran best or did your tunning make you chose that rich?
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
