Well, I’ve begun checking out my bike. Cranks fine and compression is normal for my ride – it does need a ring job. While I was at it I adjusted the cam chain tensioner per procedure. Plugs look fine.
I’m rigging my Dynacoils for install per the tech tip so I’ll swap out the coils in a day or two.
I find it hard to examine the pick up coil wires closely though from feeling them it seems one may be broken. But both sides?
Aside from the stretch test can they be tested for ohms. The book says to disconnect the four prong from the TCI and check the leads, 720 ohms they should read. Otherwise replace the p/u coils.
I’ve a spare p/u coil. How do I swap it? I know how to remove the unit but what about the cable. Looks like it runs under the shift cover with two clips and a grounding wire attached to the case. Do I have to drop the left muffler to get at that screw? The cable then runs under the middle gear boot then where it goes and where it ends I can’t tell. Behind the fuse block cover?
