Rings
    Rings
    Who makes rings for the XS's. I am going to need some rings most likely. probably ones that are larger sized. Also do I need a gasket on the bottom of the jugs or can I use RTV? I ask because it would be cheaper for me to buy the head gasket and the valve seals separately than it would to get the whole gasket set, unless there is some reason for me to get the whole gasket set?
    TIA
    Preferably something cheaper than the $72 Bike Bandit set!
    • 7588
    Get the gasket set! It's about $87 on ebay if you look. Rings will COST! I think they are about $50 PER SET from Yamaha! You may be better off looking for a set of used pistons/rings/barrels to put in. Or, just get it running for now and put a big bore kit in this winter!
    • Guy_b_g
      • May 2007
      • 790
      • Beverly Hills, Florida
      Here is a set of all the rings for all four cylinders .25 over on Ebay, 40.00.
      There were two sets, I bought the other one.
      Hey guys, I wasn't thinking..please give Nate first shot at this..I should have PM'ed him.
      Guy
      '78E
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        Rings?
        1st, why do you think you need new rings? Next, why do you think you need oversized rings with stocks pistons? If your cyl's and pistons are within spec. and your rings are not broken, a ball hone and good cleaning of all piston groves and carbon remove should be enough.
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • Guy_b_g
          • May 2007
          • 790
          If your asking Nate, he'll have to answer.
          As for me, the set I bought is going on the shelf along with a set of .25mm oversize pistons for a rebuild in the future should I need it done.
          Guy
          '78E
          • b.walker5
            • Feb 2009
            • 1745
            • Invercargill, New Zealand
            Hi Nate, check this link out http://www.xs11.com/forum/showpost.p...2&postcount=46 some of us done some donkey work a while back looking for alternatives and this is what was found. Read the whole thread for the background info.
            • Lamric
              XStremely XSive(Deceased)
              • 410
              • Kenley, Surrey, England
              The 'whole thread' is here
              Brian
                The reason I am getting 1st over is because I am having problems with my rings so I do not know what I am going to find when I get inside. She runs ok and had good compression but dont know till I get in there. If I dont need them I can still file the ends and use them as standard rings not a problem.
                Thanks for the link I ordered those rings. Much better price!
                  Do I need a ball hone or can I get by with a straight stone hone?
                  • Incubus
                    • Aug 2006
                    • 1003
                    • Austin TX
                    I'm confused, Nate (not really an unusual situation, granted). If you have good compression and your bike runs good, what problem are you having with your rings?
                    Patrick
                    XS11F (Incubus, daily rider)
                    1969 Yamaha DT1B
                      I am burning oil like a SOB. I go through about 1.5 quart in 100 miles. So something is wrong. I would much rather have the parts I need in case and then If I dont use them I am sure someone else could use them. I just dont want to pull the head and then have to wait a week to get parts.
                      • tinman905
                        • Aug 2007
                        • 946
                        • Orangeville,Ontario ,Canada
                        Do a leak down test before you tear anything apart that will give you a better idea where your problem might be. If your leaking through your rings you will hear air coming out your crank vent.
                        BDF Special
                        • XSive Okie
                          • Jun 2010
                          • 281
                          • Enid, OK
                          If these bikes have them, possibly valve stem seals? Or maybe worn guides? I would think broken and/or worn rings would show weak compression, probably around 90 psi or less.
                          Richard
                          '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
                          '02 Honda VTX1800C
                            I have valve stem seal ordered as well. can I buy a bushing to thread into the spark plug hole so that I can hook it up to an air compressor?
                            • XSive Okie
                              • Jun 2010
                              • 281
                              • Enid, OK
                              Do you mean to pump the cylinder up in order to hold the valve in it's seat (for spring removal and such), or to check compression?
                              Richard
                              '02 Honda VTX1800C
