I decided to replace my butterfly valve seals and upon removing my butterfly valve, it got bent because it was so hard to remove. I tried to flatten it back out but just made things worse due to the soft material. I will most likely need a new one or maybe a whole set. Does anyone know where to find these, as I cannot find them anywhere?
Butterfly valve trouble
1979 XS1100S
4 into 1 Mac Header (No baffle)
4 single air pods
Carb settings:
45 pilot jet
137.5 main jet
Needle clip 3rd position
25mm float height
100mm stretched diaphram springsTags: None -
I cant seem to find any anywhere either. Mikes XS has the shaft seals that I think are the right ones, but thats not what your looking for. You might have to get ahold of Mikuni and see if they have them or buy some parts carbs.Nathan
Theodore Roosevelt -
If you find a beat up carb that you can salvage a butterfly from, be sure to grind off the peening with a dremel. When you install the new butterefly, it would be a real good idea to use a drop of blue loctite.
If you verify which carb you need a butterfly for, and that it is for a '79, there should be lots available here.Ken TalbotComment
If anybody reading this has some for sale, please let me know. I need to ride!!1979 XS1100S
4 single air pods
Carb settings:
45 pilot jet
137.5 main jet
25mm float height
100mm stretched diaphram springsComment
Butterfly Valve Trouble Too
Drumagician,
I too, bent mine up a bit upon removal. I lightly hammered it back as best I could and then rubbed it back and forth asross a file to further flatten/smooth it out, and did the same to maintain the circumfrunce and bevel on the edges (CAREFUL, not too much).
It turned out quite good and the bike runs well.LuckyEddie
1980 XS1100LG Midnight special
1982 XV750J Virago
1976 GL1000
1978 GL1000 Supercharged
1981 XV920RH (chain drive)Comment
I has that idea as well but was not sure how precise these things need to be. I think it would be very hard for me to get it back to perfect condition. I would think that getting the angle correct on the edge after filing would be next to impossible. But your right, it probably could be done with enough patience.1979 XS1100S
4 single air pods
Carb settings:
45 pilot jet
137.5 main jet
25mm float height
Fix
If you haven't done dammage with your hammer, Lay them between two pices of "hard wood" with a "flat" side facing valve's. You can press them in a "good" vice, or tap them flat with a hammer. When you re-install them, use a good lock tight on screws, JB weld works nice. You can clean up the edges with an emri board, just remove burr's1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
I have some for sale. You can PM if interested.'81 XS1100 SH
Sep. 12th 2015
RIPComment
