carb/airbox question
  • 1st bike
    • Nov 2009
    • 258
    • indiana
    i am confused. i was going to pull my airbox tonight, the whole thing, top and bottom, to get a good look at the back of my carbs. hopefully, i'll be able to spray some carb cleaner in there, and break up whatever is causing my problem. (damn sea foam did too good of a job i think, and got some crap in the carbs).
    here is my question. i was reading the carb tech tips, and they all say getting the airbox out is a pia. maybe i mis-read or misunderstood. can someone please let me know if i can just pull the airbox and the boots off of the carbs and get at the back? i don't want to mess with the v-brace apparently, because that sounds like it is a can of worms i don't wish to open. please help, i am gonna get after this thing in a hour or so.
    thanks!!!
    1980 XS 1100 Special (working to be my daily ride)
  • 65oldsboy
    • Jun 2008
    • 201
    • Perry Hall, MD
    In order to get the airbox out, you need to pull the carbs first. So, I don't think your plan will work. To get the carbs out, you need to loosen the clamps on the front carb boots and the airbox boots. You can remove the 3 airbox bolts (1 on each side and 1 on top) and push the airbox back to help in getting the carbs out. There is not enough room to get the airbox out without removing the carbs. There is not enough room after you push the airbox back to really get a good look at the carbs. If you do have some crud in the carbs, they probably need to be pulled and cleaned anyway. Check the tech tips for help. Don't mess with the bolts/screws that hold the v-strap onto the airbox.
    79 XS1100 SF - name TBD - possibly "Divorce Maker" Kerker 4 into 1, K&N filter in stock air box
    79 XS1100 SF - parts (for now) - "Divorce Maker II"
    79 XS1100 SF "The one that got away" sold in 1993.
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      As stated, to get the airbox off you first need to remove the carbs. I once made the mistake of taking off that V bracket on the top of the airbox. Plan on about an hour to get that thing back together. Definitely not an enjoyable experience, thats for sure!
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
        Yup I took the v braket off the first time too, only took about 15 minutes to put back together (with the pieces that I could find, can only use 3 of the wing bolts cause I lost one of the aluminum bushings it screws into). Just pull the carbs and clean them. Even if you have never seen the inside of a carb as long as you take your time and just do one at a time you cant screw much up!
        • 1st bike
          • Nov 2009
          • 258
          • indiana
          not the answer i was hoping for, but thanks for the help. i guess it is time to bite the bullet and pull the carbs and clean them. i was hoping for an easier solution, but you know what they say about the easy way....anyway, thanks.
          • Rstyduck
            • 107
            Now ya tell me. What a PITA putting my airbox back together yesturday.
              Dont you just hate finding things out the hard way!
              • DenyP
                • 599
                • Staples, Minnesota 56479
                I believe the one thing everyone will agree with here is there are no quick and easy solutions with these carbs. They gota be tore down and cleaned! The bright side is they aren't that hard to do and lots of good info available here.
                Deny
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  Yup, when I changed my engine I did it the wrong way. It took a lot of work to get the airbox back together right. So I'm not doing it the wrong way again!
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    carb's
                    It is not a car. Spraying carb clearning down the carbs will do less then nothing. It is a bitch, but pull the carbs, keep a 4 carb parts apart. clean and adj. to exact spec! The carbs on these are where most prob. come from. Don't be scared, just follow the advice from this site, then sync. adj. and pray.
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      And when you get the airbox off, store it carefully to sell to one of the purists who will think it's a good thing to have.
                      Fit 4 of MikesXS pod filters that have XS stamped into their ends instead.
                      They are magic. Once you can get at the carbs in a few moments and not bust your knuckles doing so you will find that you'll hardly ever need to work on them.
                      • 1st bike
                        • Nov 2009
                        • 258
                        • indiana
                        fred....i have read enough to believe that if i switch to pods, i'll never get the thing to run right. i actually want to ride the bike, not just look at it. i'll keep the box....unless you offer enough money for it for me to buy a new bike, that is....
                          Hi1st,
                          FWIW, my XS11SG runs just fine using pods from MikesXS on the inlet and 1960s Triumph mufflers on the exhaust.
                          I jumped the main jets up one size and opened the slow running needles a half-turn is all.
                          By all means feel free to keep the stock airbox on your bike if it will make you feel more secure because even if I could find that much cash there's those closer to me that have a better claim.
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Oem
                            Hi 1st bike, I agree, keep it OEM as you can, then all the spec, books and manuals will apply + I think part of this bikes style comes from those great looking chrome sides on that air box JIMHO
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • cywelchjr
                              • 4450
                              • Sacramento, CA
                              I agree, and was thinking that even if I jump to pods, I will probably figure out a way to gut the airbox and put the pods on the ends of the existing stacks. That would hide the pods, keep the look of the box, and still make it easier to get the carbs in and out.
