A rear wheel can of worms
  • 81xsproject
    • 3185
    • Fortuna, CA
    I pulled off the rear wheel to change the tire and decided to change the bearings. I already have the discontinued bearing but need the other one and the seals. Anyone know a good source?
    Next, I am replacing my warped (ebay rip-off) rotors with my old stock ones. However, the paint is sort of dodgy and I was thinking of re-painting them when I recalled a friend recently informing me that he has access to a bead blasting cabinet at work if I ever wanted to blast something. Do you think it would hurt the rotors to blast 'em? I would think they would be hard enough but don't know.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • 7657
    Bearing and seals can be had from the local bearing supply store. Bead blasting will NOT hurt the rotor. A carbide drill bit and some holes will also help with wet braking. High temp paint works on the inside of the rotor, as it WILL get hot under a long run on highway 101 or 1 on the coast.
    • Elevener
      • 608
      • small town in TEXAS
      I got mine from bikebandit. OEM yamaha.
      Trapped in time. Surrounded by evil. Low on gas.
      1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
        Partsnmore has them as well.
        Partsnmore has them.
        WHEEL BEARING
        Fits: Rear Right Side, XS1100 (78-81).
        High Quality - Made in Japan.
        6304-2RS Bearing.
        $10.00US EA.
        Part#28-6304
        • perurider
          • Apr 2010
          • 121
          • Peru, Indiana
          How does a person know if the bearings need changed? mileage on you ride?
          Also, those pads you can buy for stripping paint(they look like a scotchbrite pad dipped in plastic) on a drill around your rotor in a half circle get rid of grooves but, don't get too crazy and grind in one spot too long, looks really good also, IMHO.
          '79 XS 1100F
          • 81xsproject
            • 3185
            • Fortuna, CA
            I stuck my finger in mine and spun it. It didn't feel smooth. The movement was sort of chucky. Plus I have never changed it, so it is probably original.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • b.walker5
              • Feb 2009
              • 1745
              • Invercargill, New Zealand
              As Ray said, the bearings should be available at almost every bearing supply store. 6304's are as common as dirt and widely used in lots of applications. They're about 6 bucks each in this part of the world, so I think the $10 US at Parts n More is a little expensive, and you should find them cheaper elsewhere. Heres some for $3.95 http://www.vxb.com/page/bearings/PROD/20mm/6304-2RS-1
              • Elevener
                • 608
                All bearings are not equal.
                • b.walker5
                  • Feb 2009
                  • 1745
                  Correct, and certainly not arguing with you, but todays price here for Japanese NTN 6304 2RS bearings is $6.30NZD, which is slightly cheaper than the SKF equivalent at $6.90, and slightly dearer that the KOYO model at $5.95. At todays exchange rate of .73 US cents to the NZ dollar that makes the average price $4.38USD. So I still think Parts N More are creaming it a bit.
                    Anything sold specifically for motorcycle applications always seems to be overpriced. Thats just the way it is.
                    • Incubus
                      • Aug 2006
                      • 1003
                      • Austin TX
                      Common bearings like these are usually readily available locally. Check to see if you have a local supplier nearby. Not only do you get to see them first, you could keep a neighbor working.
                      There are two bearing suppliers in proximity to my home in Austin. Both are staffed by longtime bearings guys and they know what the good stuff is.
                      And they are usually pretty competitive in price with online stores, if you factor in shipping.
                      Patrick
                      XS11F (Incubus, daily rider)
                      1969 Yamaha DT1B
                      • b.walker5
                        • Feb 2009
                        • 1745
                        Absolutely, I couldnt agree more. I wont even use those self scan checkout things in the supermarket because everyone of those puts at least one, or two people out of work, and I wont use them out of principle. My wife thinks I'm mad and says it because I cant work them.
                        • kjohnson
                          • Aug 2007
                          • 202
                          • Wetaskiwin, Alberta, Canada
                          I use them, but only because both before and after the self checkouts, most places around me would only have at most 3 tills open with huge lineups. It isn't that they've let people go, it is that people don't want to work is the problem here.
                          K. Johnson
                          -1978 XS750SF - brought back from the dead with carb
                          triple clean and boots
                          -1982 XJ1100J - brought back from the dead by
                          replacing motor after throwing #4 rod
                          -1985 XJ750XN - shim job, oil change, ride. not bad for
                          $500 including new rear tire.
                          • 81xsproject
                            • 3185
                            • Fortuna, CA
                            Well, I needed some other from Mikes so I over payed even more and bought his for $12 along with the seal for that side.
                            '81 XS1100 SH
                            Sep. 12th 2015
                            RIP
