OK, I did the "plug the vac. adj.". Rattel was less, so was preformance of course. Next, aginst my better judgment, I tryed the pluss gas insted of the prem I always use. Glad that works for some of your bikes, mine hates it but easy fix next tank full. My question is, would your next move be retard the timming after hooking vac. adj. again and if so, how much?
Two test?
Two test?
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Tags: None -
OK, I did the "plug the vac. adj.". Rattel was less, so was preformance of course. Next, aginst my better judgment, I tryed the pluss gas insted of the prem I always use. Glad that works for some of your bikes, mine hates it but easy fix next tank full. My question is, would your next move be retard the timming after hooking vac. adj. again and if so, how much?).
I was always taught to respect my elders, but it keeps getting harder to find one. -
Thanks CY
That is exactly how mine runs, pinging under hard excel. in high gear till 4500 rpm, then "to the moon"! I will start moving timming back 2 degs. at a time till she smooths out, thanks. As to gas grade, I live in south florida where my motor is 100 degs. when I start it up, could be part of the reason + high "moon shine" gas down here.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
I'm pretty sure from my shop days that a momentary ping as the throttle advances is ok, but once at full you shouldn't get any ping if the timing is right for the fuel and condition/design of the engine.Cy
