Replacing Front Flashers, Need Headlight Bolt
  • thewright1
    • Aug 2009
    • 198
    • Orange County CA
    Hi All,
    I'm replacing my front flashers but I'm first trying to figure out how on Earth to take them off, but once they do come off, is there some kind of bolt or something that would need to go in place there? Does anyone have any pictures or something that I can see? Thanks in advance all.
    1980 XS1100SG
    In the process of making her look pretty!
    P.S., TomRodgers has the best avatar icon ever!
  • Mr.Bill
    • Aug 2009
    • 118
    • Clarksburg Maryland
    This help ?
    1979 XS1100SF.
    "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
      • 2054
      They connect inside the headlight bucket.Take the 2 Phillips head screws that attach the headlight assembly to the bucket and remove the outer ring.Inside you will find how they are connected-on mine by a nut and washer.Disconnect the wire and undo the nut and washer and the flasher should come off.Hold the ground wire as you remove the nut and washer so it doesn't spin and break.
        • 2054
        Once the signals are off what do you want to do with them?I replaced mine several years ago because they stick out too much for my liking and got mini signals that i mounted elsewhere on the bucket.I used a bolt and nut to hold the bucket to the ears.
          Like Oldyam stated, the turn signal stalks have a "bolt" stem that goes through the headlight brackets or ears and through the side of the headlight bucket. Once inside the bucket, a large washer goes on followed by the ground strap ring and then a lock washer and nut.
          Pull the headlight bulb and trim ring off and disocnnect the connector, then remove the two nuts on the two turn signal stalks along with the ground wire and pull the power wire form the push in connector inside the headlight bucket. The turn signals will then pull out, but you wil have your headlight without support to the brackets. You could probably buy a carriage bolt or the like to put in the turn signals place or it may need a large washer on it. But you will need something to connect the headlight back to the brackets.
          • thewright1
            • Aug 2009
            • 198
            • Orange County CA
            Got it, thanks guys. I'm not sure what I want to replace the headlights with just yet so I've been trying to find some "inspiration" photos to give me some ideas.
            1980 XS1100SG
