I am putting an oil cooler on my bike. The adapter plate has 1/4-inch ID fittings. The cooler I have has 3/8-inch ID nipples. I can't find couplers locally to go from one size to the other and if I get 3/8-inch ID high pressure line it is impossible to squeeze it over the cooler nipples, which are 1/2-inch OD. I did stretch regular 3/8-inch fuel line over the cooler nipples. but the first time I started the bike that line ruptured, painting the front of the garage. It was a pretty spectacular failure. Looked like a nozzle.
SWMBO is really unhappy about the oil on the front of the garage. She told me to clean it off. I told her the next rain would clean it off. She said that would get oil all over the ground. I told her, hey, this is Texas, the ground is already full of oil. She said shut the F up and clean off the garage. She did not say it that nicely. I am currently in hiding.
But I digress. Will I cause a drop in oil pressure if I replace the fittings on the adapter plate with 3/8-inch ID fittings? Would any drop in pressure be hazardous to my motor? Sadly, I installed the adapter plate before I found out that fuel line would not handle 60-80 pounds of pressure. I am just happy I painted my garage instead of my tires at 75 MPH.
Opinions desired.
Patrick
Opinions desired.
Patrick
