carb float
  • jaimes-duran
    • Oct 2009
    • 44
    • Wake Forest, NC
    carb float
    Hi everyone its been a while since I've been on. Thats because thanks to you guys I've been enjoying my bike. I have one of my carbs rigged but wanted to know if anyone could help me out. I need a carb float. Does anyone have one sitting around? I have a 1979 xs1100s with stock carbs with the brass floats. Just let me know what you want for it. Thanks
  • jaimes-duran
    • Oct 2009
    • 44
    • Wake Forest, NC
    I also am looking for exhaust nuts if anyone has those or knows where I can get them. Plain ones are a pain.
      Post on the Wanted to buy section for the float. I needed one a couple weeks ago and got one pretty quick by doing that.
      For the exhaust nuts just go to Fastenal or someplace like that (I am sure you have one somewhere near you) and you can get any nuts or bolts you need in pretty much any finish you want usually on the spot.
      • jaimes-duran
        • Oct 2009
        • 44
        • Wake Forest, NC
        ok thanks I'll give it a try.
        • Rickrod3
          • Jun 2009
          • 721
          • Oakland, New Jersey
          I have a 79F. When I needed floats, I replaced them all Mikes XS plastic floats.
          http://www.mikesxs.net/
          650SF
          XS1100SG Project bike
          • 81xsproject
            • 3185
            • Fortuna, CA
            I might also have an entire set of plastics to sell. I hate the brass ones, but I do think I have some of them around as well. There is also lots of info on here about repairing the brass ones.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • Toolmaker Tim
              • 671
              • South Bend, Indiana
              Exhaust nuts
              I went to my local True Value and got 8mm chrome acorn nuts. I am slowly replacing all my phillips head screws with stainless socket head or button head screws. When I need those I go to W.W. Grainger, if they aren't in stock they usually are there the next day. They are cheaper there than at a hardware store when you buy in quanity. Just my.02 worth
              Have you gotten a float yet?
              1979XS1100SF
              K&N's and drilled airbox
              Jardine 4in1
              Dunlop Elite 3's
              JBM slide diaphragms
              142.5 main jets
              45 pilot jets
              T.C.'s fusebox & SOFA
              750/850 FD mod.
              XV 920 Needle Mod.
              Venture Cam Chain Tensioner
              • CatatonicBug
                • 6117
                • Clinton, UT
                Exhaust Nuts
                Bike bandit sells 'em for $4.98 each. There's also a set (all 8) on ebay for right around $35 shipped.
                • jaimes-duran
                  • Oct 2009
                  • 44
                  • Wake Forest, NC
                  no I haven't obtained a float yet. To be honest I would like to replace with a brass one. If I used a plastic one I would have to change the others right? do you know the part # for those nuts on bike bandit?
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    exaust nuts
                    Still adv from most yamaha dist. under $4.00, here is a like to one.
                    http://www.yamahapartsnation.com/pag...FQuenAodSmVJLQ
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • mikubuilder
                      • Jul 2011
                      • 548
                      • Westland, Mich.
                      that's my question too, and I think you have to change them all....
                      Nick
                      1982 Virago 750 (it's alive!)
                        • 5051
                        If you check actual resulting fuel heights with a manometer, you could mix float types. I have not done that, but there is no reason that you couldn't do that.
                        • foreda
                          • 949
                          • Southwest Louisiana
                          Brass float
                          I have some brass floats.. PM me if you still need one.
                          78 XS1100E Standard
                          Coca Cola Red
                          Hooker Headers
                          http://i408.photobucket.com/albums/p...m/DSC00580.jpg
                          1979 XS1100 Special
                          http://i408.photobucket.com/albums/p...m/DSC00612.jpg
                          1980 XS Standard
                          http://i408.photobucket.com/albums/p...m/DSC01137.jpg
                          2006 Roadstar Warrior
                          http://i408.photobucket.com/albums/p...um/warrior.jpg
