Hi everyone its been a while since I've been on. Thats because thanks to you guys I've been enjoying my bike. I have one of my carbs rigged but wanted to know if anyone could help me out. I need a carb float. Does anyone have one sitting around? I have a 1979 xs1100s with stock carbs with the brass floats. Just let me know what you want for it. Thanks
carb float
Tags: None
I also am looking for exhaust nuts if anyone has those or knows where I can get them. Plain ones are a pain. -
For the exhaust nuts just go to Fastenal or someplace like that (I am sure you have one somewhere near you) and you can get any nuts or bolts you need in pretty much any finish you want usually on the spot.Nathan
Theodore RooseveltComment
I have a 79F. When I needed floats, I replaced them all Mikes XS plastic floats.
http://www.mikesxs.net/XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
XS1100SG Project bike
http://s910.photobucket.com/albums/a...t=DSCF3034.jpgComment
I might also have an entire set of plastics to sell. I hate the brass ones, but I do think I have some of them around as well. There is also lots of info on here about repairing the brass ones.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Exhaust nuts
I went to my local True Value and got 8mm chrome acorn nuts. I am slowly replacing all my phillips head screws with stainless socket head or button head screws. When I need those I go to W.W. Grainger, if they aren't in stock they usually are there the next day. They are cheaper there than at a hardware store when you buy in quanity. Just my.02 worth
Have you gotten a float yet?1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
Exhaust Nuts
Bike bandit sells 'em for $4.98 each. There's also a set (all 8) on ebay for right around $35 shipped.1980 XS850SG - Sold
-H. FordComment
no I haven't obtained a float yet. To be honest I would like to replace with a brass one. If I used a plastic one I would have to change the others right? do you know the part # for those nuts on bike bandit?Comment
exaust nuts
Still adv from most yamaha dist. under $4.00, here is a like to one.
http://www.yamahapartsnation.com/pag...FQuenAodSmVJLQ1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
that's my question too, and I think you have to change them all....Nick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
If you check actual resulting fuel heights with a manometer, you could mix float types. I have not done that, but there is no reason that you couldn't do that.Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
Brass float
I have some brass floats.. PM me if you still need one.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
