Petcock Gasket
  • Never2L84Ridin
    • 84
    • Northeast, KS
    Petcock Gasket
    I'm needing to get a pair of petcock to tank gaskets. Does it matter from a standard or special? Bought a different tank and now plan to transfer the petcocks over. Is that the only gaskets i need to replace?
    Thanks in advance
    "Watchout for the guy behind the guy in front of you"
    1980 XS 1100 SG
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Gasket
    Here is a link to some on ebay, check for fit but most are same.
    http://cgi.ebay.com/ebaymotors/Yamah...Q5fAccessories
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      I've only owned the specials, they use one solid O-ring shaped into an oval. I believe the standard petcocks may use the ones shown in that ebay ad.
      You may want to completely rebuild the petcocks while your at it, especially for the Special style. The six part kit (three for each side) is available from Georgefix on ebay and one of them is the seal your looking for. On the standard petcocks it seems the new vac diaphrams have a valve that is JUST smaller than the stock one and do not seal really well.
      In fact, here is the kit for Standards.
      And here is the special kits. I forgot it includes the diaphram to rebuild the Octopus valve.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Gasket
        Sorry, are you putting a special tank on or a standard or vise-a versa? If you are changing from one to another you should use the petcock and gasket for that tank style. Both have diff. spec. for seal/screen/ ect. All will feed the carb's if set up right.
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Personally I just used RTV and have not had any problems!
            • 7831
            If the old "O" ring is in good condition, you can re-use it. The Standard and Special use DIFFERENT petcocks! The bolt spacing is 10mm less on the Special, so no, the gasket will NOT interchange.
            As stated, use georgefix on ebay for rebuild parts. He is very good about getting you the correct rebuild kits for carbs, petcocks, and brakes. All work except for the Standard diaphragm as previously stated.
