i've been having problems since i last took my carbs off, didn't adjust much so i'm afraid to do so now as it was running really well before
this thread shows what i did
i've got it back together and its running poorly, wont idle without choke and alot of popping from the right tailpipe, hopefully this video is helpful.
i turned out the mixture screws, which i guess i can continue to do but i hadn't adjusted it and it was running well before so i dont know why that would change just from remove the rack and putting it back on
i haven't snyc'd so maybe that is my problem, i didn't break the rack apart but who knows. all the floats are set to 25mm, any other ideas?
When you say you turned out the mixture screw are you talking about the idle mixture screw.
Those are preset to 1 1/4 turns out and should be left at that setting. As it will quickly show, my expertise is limited although it seems like in the last 3 months I've had enough experience to qualify as a tech on the '79 XS1100SF.
Now I'm dealing with electrical issues... maybe my TCI box.
From viewing/listening to your video, it leaves me wondering, have you pulled the plugs to check them for coloration?
Life is good. Especially when the XS-11 is running XSively well.
