top end gaskets?
  • xsbobber817
    • Mar 2010
    • 14
    top end gaskets?
    Does any one know a place where i can just get top end gaskets rather than a whole gasket set?
    I dont really wanna pay almost $100 for just a head gasket base gasket cam cover gasket and exhaust gaskets.
    if you could direct me where to go that would be great, thank you
    • 8863
    Try ebay...
    http://shop.ebay.com/i.html?_kw=xs11...ts_Accessories
    Bikebandit...
    Yamaha...
    Partsnmore....
    http://partsnmore.net/
    Boats.net....
    http://www.boats.net/
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      If you can get some gasket paper, you can cut your own from the templates here http://www.benefiscal.co.uk/forum/in...43573#msg43573
      • esw1104
        • Apr 2006
        • 48
        • Calgary Alberta Canada
        To make extra gaskets for my engine I took the part i wanted ran a bead of oil around the gasket edge with my finger then pushed it down on a sheet of gasket paper (from Canadian Tire or UAP or Partsource or just about anywhere)
        that left a perfect image and then i cut the gasket out with a sharp knife (Exacto knife or very sharp pocket knife or even scissors )
        I hate buying extra kits for one or two gaskets.
        • xsbobber817
          • Mar 2010
          • 14
          i like doing my own gasketts but isnt there like metal in the head gasket? would i be able to cut it? thank you
          • jmnjrpa
            • Jun 2009
            • 863
            • Lewisville, Texas
            You can usually find head gaskets seperate. I would not try to make those.
            Original except:
            Big John
            • CatatonicBug
              • 6117
              • Clinton, UT
              I agree. The head gasket is really the only gasket you need. All the others can be sealed very easily with RTV (or your favorite HT-gasket-in-a-tube). No need to mess with paper. Of course, the exhaust gaskets might also be a candidate for purchase, but they aren't plain paper anyway.
              • dbeardslee
                • Nov 2007
                • 4385
                • Maineville, OH
                No, you can't. The head gasket has integral 'crush gaskets' around the cylinders, and without them it probably isn't going to withstand the pressure. There are some on ebay in the $50 price range, but someone had a post up not long ago for a place that had them for $25 each. The valve cover gaskets can be hand cut, but they're big and probably more trouble to cut than they're worth. Here's a place you can get a valve cover gasket for $10 - probably cost you almost that much for gasket material.
                When you put your head gasket on, don't forget to retorque it after the motor has warmed up and cooled back down. I just replaced one on a 79SF that had blown out due to improper torquing. Additionally it had an aluminum washer substituted for the fat steel ones that are supposed to be there, and missing cam tunnel bolts, which I'm sure didn't help things. For whatever reason, there were several head bolts that had to be re-torqued four times before they stayed put. Sometimes you've got to keep an eye on them for a while, but luckily you can get a torque wrench in there without removing the tank. My $.02
                  so when you say 'top end" are you asking about the valve cover or the head gasket or both. either way like what has been said RTV works great for everything on this bike except the head gasket and exhaust.
                  • dbeardslee
                    • Nov 2007
                    • 4385
                    • Maineville, OH
                    Here you go...
                    Here's a head gasket for $23.74.
                    • xsbobber817
                      • Mar 2010
                      • 14
                      i dint really think u could do a head gasket, ill buy that and use rtv for the rest? i just had my cylinders honed so yea thanks tho
                      • b.walker5
                        • Feb 2009
                        • 1745
                        If you can get access to the right thickness of copper sheet it's perfectly acceptable to make your own head gaskets. Its a bit of extra shagging around but they work just like any other head gasket. I havent made one for my bike, but have made many over the years for V8's and never had a problem. Heres a link to a crowd that make them for the racing and vintage scene, and they're nothing more than stamped copper sheet. That being said, if you've found one for 23 bucks then there's probably no point stuffin' around with making one. For those of us that sometimes dont have ready access to such parts dont be afrid to make your own.
                        • xsbobber817
                          • Mar 2010
                          • 14
                          i just bought some red rtv high temp sealent im gonna buy a head and exhaust gasket in a couple minuetes so hopefully in a few days i will have it put together, i still need to figure out the wiring, i got the bike for free so almost everything was hacked of, i am going to do a classic style xs bobber, so its gonna be fun, i will start a new thread later on. and get pics and all that stuff.
                          • CatatonicBug
                            • 6117
                            • Clinton, UT
                            Red?? Why would you use Red RTV on a silver engine? To each his own, but you do realize you'll see the edges of the seams, right?
                            • xsbobber817
                              • Mar 2010
                              • 14
                              haha idk i asked the guy for hightemp rtv sealent and he handed me also bought a head gasket should be here in a few days
