spark plugs pic
  • kevxs
    • Apr 2009
    • 353
    • toronto
    yeah lines were a little kinked, its running slightly better now but still poppin like crazy from the right pipe
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
      Float height might be low and/or idle mixture screws in too far. Try the mixture screws first.
      • kevxs
        • Apr 2009
        • 353
        • toronto
        i wondered that but i haven't adjusted those (aside from swapping the floats in 1&2) and it was running excellent before i took the carbs off seems like (due to the popping) the problem is coming from 3&4 which i didn't even touch . . . still wont idle either
        Green Dyna Coils
        1973 CB100
        kevXS
          Maybe the tank is low on fuel? Did you try running in the prime position?
          • kevxs
            • Apr 2009
            • 353
            • toronto
            yeah i put gas in it and tried in prime and reserve , looks like the boots are sealed on good . . .
            Green Dyna Coils
            1973 CB100
            kevXS
            • kevxs
              • Apr 2009
              • 353
              • toronto
              just pulled the plugs and they are dry black, i only drove around the block a couple time so i don't know if this helps
              Green Dyna Coils
              1973 CB100
              kevXS
              • kevxs
                • Apr 2009
                • 353
                • toronto
                still haven't fixed this, any more suggestions?
                thanks guys
                Green Dyna Coils
                1973 CB100
                kevXS
                • kevxs
                  • Apr 2009
                  • 353
                  • toronto
                  still confused
                  so i just checked and 3&4 had gas in the bowls, bike runs about the same even with those bowls drained, so i'm thinkin my problems lies there, again it was running great, all i did was take off the carbs and swap the 1&2 float bowls, i've also double checked my fuel lines for kinks and proper routing, vacuum lines seem to be in the correct position also, NEED HELP the weekend is here!!!
                  Green Dyna Coils
                  1973 CB100
                  kevXS
                  • kevxs
                    • Apr 2009
                    • 353
                    • toronto
                    spark is good on all 4 also, i guess i'll swap the bowls back and pray
                    Green Dyna Coils
                    1973 CB100
                    kevXS
                    • kevxs
                      • Apr 2009
                      • 353
                      • toronto
                      all bowls have just under 4oz of fuel in em, except number 2 which was a little less than that. (i put the number 1 float bowl on number 2 and adjusted it as i was suspicous that float as rich) i'll adjust it back
                      Green Dyna Coils
                      1973 CB100
                      kevXS
                      • BigRed
                        • Mar 2010
                        • 265
                        • Ottawa, Ontario, Canada
                        Pretty sure you have to go further than around the block. I go for a 20 minute ride before trying to read plugs. They have to get up to their self cleaning temperature to give you an accurate read.
                        Good luck
                        • Crazcnuk
                          • 2980
                          • Hinton, AB, Canada
                          To get an 'accurate' read on plugs, can take couple hundred miles. The engine has to be at full operating temps, choke off, etc.
                          The only exception is doing the 'chop' test, which looks for slightly different things.
                          When I first got my carbs running properly, they looked white for about 300 miles, when they started to get the light tan tinge to them.
                          '05 ST1300
