I am going back into a tranny. But I would like some thoughts.
On the Banshee, I did the dremel fix some time ago. No more slipping or machine gun effects. But, in first gear, when you first get on it after it has been engaged, it feels like it gets pulled in and hits.
I can put it in gear, let out on the clutch, and go down the road almost half a mile, then hit the throttle just a bit and BAM like someone hit you from behind, and it never does it again, and will not slip at all. ITs like the old first/second slip, but only one slip, then locked in.
But really, I can't go very far. The leg is still not quite up to holding the bike up or any "abrupt" forces. But it also definitely does not do it in other gears, only first.
