kick start gear
  • perurider
    • Apr 2010
    • 121
    • Peru, Indiana
    kick start gear
    ok got in countershaft..but s--t forgot about kick start gear, do i need it because I am TOTALLY over this bike!! I just want it back together, I pulled the shift fork shaft(again) and dropped the coountershaft(again) but now that f---reaken kickstart gear is in the way. now I am picturing an xs on fire and watching with a rolling rock in my hand!@!!
    '79 XS 1100F
    IF you don't want to use the kick start, you don't "need" it. Just keep the outside part so you don't have a big oil leak!
    • perurider
      • Apr 2010
      • 121
      • Peru, Indiana
      so the splined part on the clutch cover will be good?
      '79 XS 1100F
        As long as you have the kick start boss installed (held on with 3 bolts), then you can install the outer shaft in it, and then thru the clutch housing without it leaking oil. It will be immobilized without those inner gears installed though. I eliminated my kick starter altogether by passing a 1/2" carriage bolt with a rubber washer thru the clutch housing, and a washer and lock nut on the inside. Got rid of the entire shaft. Did that 5 yrs. ago, no leaks. HTH
