Spark Problem
  • BritinNH
    • Feb 2010
    • 14
    • NH
    Spark Problem
    Hi anyone got any suggestions for a little problem i have.
    Went to start the bike for the first time since i put it back
    together.
    Now if you have all 4 spark plugs in she wont start so i pull one to check spark, ground it on cylinder and she starts right up, put the plug back in wont start, pull the opposite plug starts right up , plug in no start.
    Doesnt seem to make any difference which plug you pull out, with 3 it starts but with 4 it wont.
    thanks
    1979 xs1100 (un named)
    Kerker 4-1 Exhaust wrapped
    Drilled Rotors
    K&N Air Filter
    XS850 Kickstart
    Manual Petcocks
    1972/75 XS650 Brit Style
    http://www.youtube.com/watch?v=OFjeCVHqTEY
    2007 Kawasaki Z1000 stock
    • 7794
    Check that you have the plugs wired to the correct piston! IIRC, the left side coil fires piston 2&3, and the right side coil fires 1&4. The second thing to check is the resistance of the spark plug caps. They should be 5K Ohms if they are stock. If ONE cap is 6K Ohms or higher, the coil will only fire one plug in open air. Third check, unscrew the plug cap, and cut 1/4" off the end of the coil wire, reinstall the cap. If you have some oxidation of the copper wire, it will also cause a missfire.
    You DO have new plugs in, correct?
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      Could it be that you have the coil wires on backward, you know, the gray and the orange ones? Could be grounding out the whole ignition system? Don't know.....JAT.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
      • BritinNH
        • Feb 2010
        • 14
        • NH
        Yep brand new plugs ,new ingnition wires , new 5K NGK spark plug caps too,tested resistances everything looks good
        Drilled Rotors
        K&N Air Filter
        XS850 Kickstart
        Manual Petcocks
          Still sounds like a weak spark situation, it'll fire in air but not under compression. You've got a 79, so it has the ballast resistor if it has OEM coils. You stated new wires...so thinking you did the new wires in old coils repair. Did you test the primary and secondary resistances on the OEM coils while the wires were disconnected, or at least before you put the new plug caps on??
          Also, how much voltage are you reading at the ballast resistor....harness side before it goes into the resistor, as well as after the resistor. SHould be 12 going in, and about 9 going out. IF the voltage going in is much less, then that can also be causing a poor spark. A quick test would be to bypass the BR and see if it will start on all 4 plugs. IF SO...then it's a weak spark for some reason. IF it won't start...then I don't know??
          • BritinNH
            • Feb 2010
            • 14
            • NH
            Thanks TC ,yep i did remove the original wires and replaced with solid core
            accels , in the excitement of my 4 year old going to see the fireworks last night i forgot to switch off the ignition so as soon as i charge her up again
            ill take a look at what you suggest.
            Drilled Rotors
            K&N Air Filter
            XS850 Kickstart
            Manual Petcocks
            • petejw
              • 2269
              • sydney australia
              might also be worth while checking your
              ballast resistor located under the tank, you can
              bypass it for a short time by connecting the two
              wires together.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
