Yikes! I've lost my rear drive bolts!
  • mfarrington
    • Oct 2007
    • 223
    • Suwanee, GA
    did an engine swap from the 80 to 79, and in process lost the 4 bolts which connect da shaft to da final drive. Can someone help me identify them so I can run down to the auto parts store and complete my install?
    "Hi, my name is Mike, and it's been 6 weeks since my last ride . . . "
    Regards,
    Mike Farrington
    Suwanee, GA USA
    Current: '80 XS11SG, '97 Vulcan 1500, '73 CB750
    Previous: '79 XS11SF, '80 XS11G, '81 XS650
    Mike, not sure of the thread size, but they are lock nuts.
    • XSokieSPECIAL
      • Jun 2009
      • 1631
      • Tulsa, OK
      Regards,
      8mm x 1.25 x 1/2" should work for you.
        • 7832
        AND THEY MUST BE A GRADE "8"!! USE hard bolts, NOT the "cheap" everyday bolts, and they should be 8mm X 1.25mm pitch X 15mm length WITH the "self locking" washer head on them! IF they don't have that, use RED locktite, otherwise I use blue on them.
        • mfarrington
          • Oct 2007
          • 223
          • Suwanee, GA
          Thanks to all for the quick replies. I love this place.
          Regards,
          Mike Farrington
          Suwanee, GA USA
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            Check in your rubber drive boot. Some folks put them in that rubber boot so they will know where they are when they get to the reconnection stage. Otherwise as others have indicated, use the right type of nuts.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
