Hi guys I need bit of help, my rev counter is a bit jumpy, what do I need to do to fix it?
Rev Counter on XS 1.1
XS 1.1 '84 Midnight Special
Honda CBX 250 2009
Kempton Park
Johannesburg
South Africa
JanTags: None -
First thing I would look at is the connections for the alternator. Under the right side cover is the fuse box and a plate it mounts to with the starter solenoid and the run signal relay. Three screws hold the plate on, pull those and carefully pull the plate out. Behind it you should see two connectors with wires from the alternator. Make sure they are good and clean. It is not uncommon for them to be burned.Life is what happens while your planning everything else!
78 XS750 -
Thanks a mil will def have a look, as the bike was standing for more than a year before I got it!XS 1.1 '84 Midnight Special
Honda CBX 250 2009
Kempton Park
Johannesburg
South Africa
JanComment
