This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
The exhaust valves are the same on all models IIRC, however, I believe the intake valves on the 80-81 are larger than the 78-79. I know they are different sizes on the intakes.
I think you are correct about the exhaust being the same and the intake being different. Dont remember the sizes off hand though.
1978 XS1100E K&N Filter
ATK Fork Brace LED Dash lights
Ammeter, Oil Pressure, Oil Temp, and Volt Meters Green Monster Coils SS Brake Lines
The intake and exhaust valves are both of a larger diameter, also the valve stems are shorter on the later valves as the valves are set more deeply into the head for clearance.
