Super tech question
  • dogyear58
    • Aug 2007
    • 45
    • cold country minnesota
    Super tech question
    Can I put second generation valves in a first gen engin?
    looks like to me the valves are close to the edge now....
    81XS1100sp full dresser.
    79XS1100sp rat bike.
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    I dont think so
    but I believe the 80s bikes havelarger valves
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
      The exhaust valves are the same on all models IIRC, however, I believe the intake valves on the 80-81 are larger than the 78-79. I know they are different sizes on the intakes.
        I think you are correct about the exhaust being the same and the intake being different. Dont remember the sizes off hand though.
        • Lamric
          XStremely XSive(Deceased)
          • 410
          • Kenley, Surrey, England
          Looks like the exhaust valves are mostly the same size - except that the heads are 1mm wider on the later ones.
          12R-12121-00-00 Early Exhaust Valves
          3H5-12121-00-00 Later Exhaust Valves
          Brian
          • Guy_b_g
            • May 2007
            • 790
            • Beverly Hills, Florida
            The intake and exhaust valves are both of a larger diameter, also the valve stems are shorter on the later valves as the valves are set more deeply into the head for clearance.
            Guy
            '78E
