#4 is cutting out on me????
  • coltrain5000
    • Mar 2010
    • 34
    • Ashburn VA
    I have a brass float I can send you. I just upgraded all mine to the plastic floats from mikesxs. PM me your address and I will get it on the way.
    1978 Macho Maroon XS1100 Mikesxs green coils, ZRX Carbs, spaghetti jardine 4 into 2
    1989 FXLR harley that is not stock
    1977 RD400 stage 2 ported with VM30 carbs
    1975 RD350 modified
    I can't leave anything alone
      So I spent yesterday trying to get my floats at least close to the same setting by doing the clear tube and liquid method. Rode it for about 30 minutes last night and it still has the bogging between 1500 and 3500 and by the end of the ride my #4 plug is still all fouled. Just for fun today I pretty much closed off the idle jet screw and took it for another 30 min ride. Same thing except somehow the #4 plug was actually worse? Hopefully I can get a float from Coltrain and maybe that will solve all of my woes!
        Part 2
        I figured I would keep this all in the same thread.
        So I got a different float today and put it in and I have all the floats (measuring each float on both sides) set to between 25.53 mm and 25.59 mm. So hopefully now with the correct float the fouling of the #4 with be done.
        After that I pulled the needles out of the diaphragm assembly to see where the needles were set. They were all set to the lowest (richest) notch and then they had 1 washer under the circlip. Now my plugs have been kind of grayish white, even the electrode and grounding strap are that color on some. So where do I go from here now...
        Also is there usually a plastic washer/bushing on top of the needle?
        Thanks in advance
        • coltrain5000
          • Mar 2010
          • 34
          • Ashburn VA
          #34
          Go with either middle groove or 4th richest groove. I just acquired my xs and they are set at 4th groove. I have done alot of research.. I read that folks like em at the middle notch no matter what mods. I am not sold on that. yet! I am gonna set them to the middle and try it next time I have my carbs off. You can see most of my settings in my sig.. we are close... My bike pulls really nice and hard. Under 3 grand is what I am trying to improve. It seems I may be a tad rich.. not sure. I do know those green coils are beasts. NICE SPARK! Low end is much nicer after those.
          Have you syncd lately? Lot of times that will clean up some low end.. Hope you receive my floats at least by tomorrow!
          1975 RD350 modified
            • 8863
            I've experimented with the needle settings on both my 11's and I've always ended up going back to the center position, YMMV.
              #36
              But the thing is, if I am already running lean and the needle is already set as rich as it can be set (other than taking out the little washers) where do I go at this point.
              If I move the clip to the middle notch then I am going to lean it out even more than it already is.
                • 8863
                The needle height is for the RPM midrange, the transition between the pilot and main jets. If your float heights and jetting is correct, it should be the least prone to "stumble" in the center clip position, YMMV
                • coltrain5000
                  • Mar 2010
                  • 34
                  • Ashburn VA
                  #38
                  Thanks bikephil! I'm putting my needles on the middle clip asap!!! probably this weekend! along with my stainless allen bolts for the carbs
                  1975 RD350 modified
                    #39
                    Ok so here is what is going on currently. All carbs are set to the same setting on everything. I moved the clip up on the needles to the center notch and removed the washer. As I said before the floats are all set to between 25.53 and 25.59. Compression is #1 150 #2 150 #3 140 #4 140. I put the carbs back on yesterday and now the bike runs worse than before. Its not fouling out the #4 plug anymore though. before it would foul out the plug by the time I was done syncing the carbs and now it does not do that (yet). Now the bike almost dies when I give it throttle. It will idle nice, I can get it to sync but when I give it throttle it will start to rev and then just drop like a rock, let off the throttle and it will go back to an idle.
                    I am getting to the end of my rope here with this bike. I need it cause its all I have to drive right now and its a little hard to get a job when I cant drive anywhere.
                    Thanks
                    Edit: also I taped over the holes drilled in the airbox.
                      #40
                      What your describing to me, sounds like a lean condition. How does it run with the choke/enricher pulled out one notch? If I lean out by putting the leve rin a notch to soon in the warmup, the bike does just that. It will idel fine, and when I give it gas, it stumbles as it tries to rev, then won't gain rpms just stumble. Let off the throttle and it idles just fine. Pull the lever back out a notch and it idles up give it throttle and it responds just fine.
                        #41
                        It doesnt fix the problem having it partially choked but it does make it a little bit better. Doing it that way it then bogs down when it hits about 3000 and if you just hold the throttle open it slowly pull through it and then it eventually takes off.
                        • Toolmaker Tim
                          • 671
                          • South Bend, Indiana
                          #42
                          Floats
                          Hey nate,I went ahead and got plastic floats from Mike's XS. I have a couple of extras, I'll let you have one. PM me your snail mail address.
                          1979XS1100SF
                          K&N's and drilled airbox
                          Jardine 4in1
                          Dunlop Elite 3's
                          JBM slide diaphragms
                          142.5 main jets
                          45 pilot jets
                          T.C.'s fusebox & SOFA
                          750/850 FD mod.
                          XV 920 Needle Mod.
                          Venture Cam Chain Tensioner
                          • Toolmaker Tim
                            • 671
                            #43
                            Ooops!
                            Didn't realize there was more than one page to this thread. I'll hang on to the float, mybe someone will need one another time.
                            1979XS1100SF
                            Jardine 4in1
                            Dunlop Elite 3's
                            142.5 main jets
                            45 pilot jets
                            750/850 FD mod.
                            XV 920 Needle Mod.
                              #44
                              Ok so I tried spraying some starting fluid in the snorkel and it actually would kill the bike (never seen that happen before like that) but when I would restart the bike I would be able to give the bike throttle normally and it would rev up perfectly without any stumbling or anything. So I quick put the bike back together and figured I would take it out for a quick test ride before the rain starts. Right when I put it in gear it started to do the same thing again would start stumbling between about 1500 and 4000. As long as I kept the RPMs above that I was ok and when it got down low it would start to stumble, as long as I kept the throttle open or pumped it I could keep it going. So I rode it hard and fast for about 10 miles. Got back and checked the pipes to see if they were all hot and #4 was hot but significantly cooler than the rest. Pulled the plugs and here is what they looked like. And #4 smelled like gas and not oil.
                              Here is the link to it as well http://i738.photobucket.com/albums/x...n/DSCN3020.jpg
                              Not the greatest picture but its better than nothing.
                                #45
                                Well, it seems your running very rich and not lean by the plugs. No 1 looks pretty nice though. Have you tuned the mixtures? Tried a colortune plug in them yet? Forgive me for not looking back through this thread, but have you looked for broken off mix screw tips? It definitely seems to be carb related.
