Oil Usage?
  • MindWebs
    • May 2009
    • 431
    • Baldwin, WI
    oil... burning...?
    yep mine loves the stuff, drinks it by the quart.
    the harder ya run'er the thirstier she gets.
    i've found it to be the rings.
    i'm not worried about it.
      • 2117
      The bike has never been rebuilt with my 35,000 miles-still original and just simply doesn't burn oil.Period.
      • esw1104
        • Apr 2006
        • 48
        • Calgary Alberta Canada
        I burned 600 ml (20.2884140014648 fluid US onces) on day one of XS north.
        Anybody behind me see smoke at XS north? I didn't.
        I tend to run 20w50 oil.
        Think its somewhat normal to burn oil for me, i think i get some blow by on piston one and the blow by make an air flow out the crankcase breather.
        Steamy hot oil from engine slowly vaporing out of the crankcase.
        Wonder if thats where our oil goes? Re-burned in air boxes or released on pod beasts.
        • Rickrod3
          • Jun 2009
          • 721
          • Oakland, New Jersey
          Cycle Worlds X Country Ride
          I remeber reading that the brand new 78 that Cycle world used in there X Country non stop ride had to be topped off.
          JAT.
          650SF
          XS1100SG Project bike
          • Crazcnuk
            • 2980
            • Hinton, AB, Canada
            "The bike has never been rebuilt with my 35,000 miles-still original and just simply doesn't burn oil.Period. "
            ALL internal combustion engines burn oil, period.
            Some just less than others. Yours just doesn't burn enough for you to worry between oil changes.
            '05 ST1300
              • 2117
              Maybe i simply don't see it-hate getting involved in oil discussions as opinions vary and what happens on one bike is not true for all bikes.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                • Fort Myers, Florida
                Oil burning?
                Any gas motor will use/burn some oil. Nature of the beast, pressure, heat, friction, ect. The harder you push the more it will use, IE, a tight motor will use X% more under high loads then under under low loads as a worn or poorly spec. motor will use X% more also under load. Most bikes have the disadvantage of being air cooled, many huge changes in temp/load. One "bad" day on your motor can cause all kinds of wear inside. Most rebuilders dont take the time to go 0 gap on rings, nor does the OEM, just takes to much time/skill. If you are burning oil and cant see smoke or plug foul. go one grade higher, ie, 10w40 to 20w50 and check compression, if that is good, check valve seals IMHO.
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • Crazcnuk
                  • 2980
                  "Hate getting involved in oil discussions as opinions vary "
                  That and most people really don't know what oil really does, how it does it or why you use the various types. Opinion has very little to do with real science.
                  They just buy into the advertising, and local superstition.
                  I chuckle when I see all the 'brand' wars, and people changing synthetic way too often, or those that use oils way thicker than they need to.
                  But, what can one do?
                  '05 ST1300
