79 SF ignition timing
  • Filter
  • 79 SF ignition timing
    What are the numbers I need to hit. Is it still :
    5 degrees @1100,vac on
    31 degrees@5200 vac off
    52 degrees @ 5200 vac on
    I know there was some tech bulletins, my vac advance mech, etc are all original.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • #2
    On my F model (U.S.) it's 10 degrees BTDC at 1100 rpms, and my Haynes manual shows the same for the SF (U.S.). Shows it at 5 degrees BTDC for the U.K. F model, but doesn't say anything about an SF U.K. model. Line up the pointer with the 'F' mark on your timing wheel at idle with the vacuum advance disconnected and plugged. With the vacuum advance disconnected and plugged at the carb it should be 31 degrees BTDC at 5400 rpms. 36 degrees BTDC on the F U.K. model at 5400 rpms.
    • #3
      Man, if your riding the F U. K. model I'd say thats some sort of bad luck.
      1979 xs1100 Special -
      My Bike:
      [link is broken]
      • #4
        Psyco - I didn't even catch that when I typed it. Now I'm laughing too . Oh well, some say I only open my mouth to change feet .
        • #5
          Timing for an SF is 5 deg and 31 deg exactly as you have stated. The F-mark on the SF timing wheel is at 5 deg while the F-mark on the F model is at 10 degrees. The 31 degrees will probably come in alot sooner than 5,200 RPM due to ageing of the advance springs.
          Mike Giroir
          79 XS-1100 Special
          • #6
            Here's the info from the Haynes manual -
