Jet Needle
  • boediddly
    • Dec 2009
    • 50
    • columbus,oh
    Jet Needle
    Does anyone know where I can purchase a new jet needle thats one step richer for the 79 xs 1100 there is no dynokit available?
  • petejw
    • 2269
    • sydney australia
    hey boediddly,
    u can always make the needle richer by
    placing a small washer under the circlip
    to raise it.
    every now and then ive seen dj kits available for the
    79 on ebay.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      The 79 should have adjustable needles in it already.
      Ich habe dich nicht gefragt.
      • Toolmaker Tim
        • 671
        • South Bend, Indiana
        Dyno Kit
        Ivan, are the Dyno kits on Mike's XS the correct ones? Just wondering. By the way, you are right about the needles being adjustable already.
        1979XS1100SF
        K&N's and drilled airbox
        Jardine 4in1
        Dunlop Elite 3's
        JBM slide diaphragms
        142.5 main jets
        45 pilot jets
        T.C.'s fusebox & SOFA
        750/850 FD mod.
        XV 920 Needle Mod.
        Venture Cam Chain Tensioner
        • boediddly
          • Dec 2009
          • 50
          • columbus,oh
          im not asking if my current jet needles are adjustable im asking nif any one has gone to the next richer one due to port and polish on the 79
          • TADracer
            • May 2006
            • 1417
            • Kenner, Louisiana USA
            My head is ported with an extra bit of valve work along with some other mods like exhaust, intake, cam timing and ignition. But aside from the head work, the motor is still stock. Center position with stock needles still works for me but main and pilots have been jetted up a few notches.
            Mike Giroir
            79 XS-1100 Special
            • CatatonicBug
              • 6117
              • Clinton, UT
              Next richer one?? As far as I know, there is no such thing. You can adjust them, but that is all the adjustment/change available/needed.
              • petejw
                • 2269
                • sydney australia
                i was reading a while back the factory pro site, that does something
                similar, ur wanting a thinner needle to give you a richer mixture,
                but i think it was a special order and it came with the emulsion tube.
                if the heads ported there should be enough adjustments on the needle
                to richen it or you could try richening your floats slightly.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • boediddly
                  • Dec 2009
                  • 50
                  • columbus,oh
                  thats the funny thing, the exhaust port was cleaned up, wasnt even a good polish , the top of the piston was polished and the carb was cleaned up( the throttle plate screws filed down and the edge sharpened . Not real serious mods , mods i have done to other bikes and didnt have to adjust anything but this bike after much trial and error wont run without the jet needles in the richest position plus three yes three half step washers.It will now run good but somewhat lean ,at first I was amazed at how little the mods were as compared with the changes in jetting,but now im wondering what is really going on ,also the compression is 170 across the board (a little high ) it has 140 mains but its starving for fuel at wot
                    • 8893
                    That\\\\\\\'s only one size larger from stock mains (137.5) for the 79 Special if you are using Mikuni jets. Dynojet uses a different number system, don\\\'t recall you saying which brand you are using.
                    • psycoreefer
                      • Feb 2008
                      • 1557
                      • Minden, NV
                      I'm by no means a carb expert but the way I understand it you won't be able to tune the midrange (with the needles) until you've got the proper size main jets. Float height can also effect this, so make sure you've got that set to spec also....
                      1979 xs1100 Special -
                      My Bike:
                      [link is broken]
                      • petejw
                        • 2269
                        • sydney australia
                        hows the bike actually riding?
                        you do need to start from the top and work
                        your way down, mains, needle, floats,
                        then always adjust mixture settings and sync after
                        each change, what ive found in general is that if the needle
                        is set at stock and is running on the lean/rich side then your
                        mains are usually running lean/rich.
                        what settings have you got ur carbs set at atm?
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
