rear wheel
  • 81 MIDNIGHT
    • May 2009
    • 2
    rear wheel
    dumb question,,with the bike on centerstand,,how much resistance should the rear wheel have,mine is really hard to turn:
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    In neutral, should roll easy.
    2011 Kaw Concours 14 ABS
    • FANNING507
      • Jul 2008
      • 103
      • south central Kansas, Turon
      Possible solution
      You might loosen the rear brake adjuster rod. I had mine too tight and it did the same thing. For what its worth. Good luck
      '81 XS11 LH (MNS)
      "On a scale of 1 to 10, I have an eleven!"
      "Excess is easier to say than XS,"
        Hi Midnight and welcome,
        remember it's a shaftie so the wheel has to move the final drive gears and the driveshaft along with it.
        It's worse than that?
        The prime suspect is that the rear brake is dragging.
        Quickie test, drive it around the block WITHOUT using the rear brake and feel the rear disk immediately you stop.
        If the disk is hot or even warm, the brake is dragging.
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          Take a rubber mallet and pound on the right side of the caliper a few dozen light blows then try again. If it's better, rebuild the caliper. Also do not use grease on the slide pins. It requires a synthetic or silicone based lube.
          Geezer
          • Toolmaker Tim
            • 671
            • South Bend, Indiana
            Be careful touching that disc after your ride around the block! If it's dragging it's going to be HOT! A couple of layers of crisp skin will just give you more resistance
            1979XS1100SF
            K&N's and drilled airbox
            Jardine 4in1
            Dunlop Elite 3's
            JBM slide diaphragms
            142.5 main jets
            45 pilot jets
            T.C.'s fusebox & SOFA
            750/850 FD mod.
            XV 920 Needle Mod.
            Venture Cam Chain Tensioner
            • 81 MIDNIGHT
              • May 2009
              • 2
              rear wheel
              yep,,brake was dragging,,,thanx yall:
