Linked brakes
  • Mike F
    • 99
    • Amesbury (next to Stonehenge)
    Linked brakes
    Hi
    Does anyone know the diameter of the plunger on the front master brake cylinder? I am replacing the rear brake on my xs with the linked braking system and am wondering if I could keep the original front master but only working on one disc. The xj has a ¾" rear brake piston while the XS has a ½" one. I am thinking that it maybe the same but opposite for the front.
    Keep revving
    Mike F
    Mike Farnworth
    XS1100 E & XS1100 Sport Project
  • Mike F
    • 99
    I have just checked th XS11's front brake cylinder and it's 11/16", anybody know the size of the XJ11's front brake cylinder? The size should be moulded on the side of the cylinder.
    Keep revving
    Mike F.
    Mike Farnworth
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      Just did a quick check on the XJ, couldn't see numbers very well. Side next to handlebar has a '14' cast into the housing; a few other single-digit number further back look like casting date marks.
      Could the 14 stand for 14 mm?
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • Mike F
        • 99
        Hi Jerry
        The numbers that I was looking at were the biggest ones there.
        I suppose it will be 14 mm as that would give pretty close the braking pressure as 1/2".
        Thanks for that.
        Keep revving
        Mike
        <Just did a quick check on the XJ, couldn't see numbers very well. Side next to handlebar has a '14' cast into the housing; a few other single-digit number further back look like casting date marks.
        Could the 14 stand for 14 mm?>
        Mike Farnworth
