Well, as a result of my recent "incident" I have a right side exhaust that was basically useless due to a large hole tore through it. Sooo, as some of the members have queried as I have int he past what exactly goes on inside there.....
The inlet into the exhast, baffle plates to restrict flow into the first soud chamber...
To exit this chamber the gasses pass through tubes to get the large end of the megaphone and another baffle plate....
Here you can look close and see the end plates in my exhaust had been drilled out....
Then the exhaust has to pass down through the holes in that end baffle plate into the second sound chamber to go out through the middle exhaust pipe...
Hope that clears some things up for someone.
