Fuel Tees
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    Fuel Tees
    Found out whats been leaking in my carbs. Scurvy little fuel tee between carbs 3 & 4 is the cause. One option is Mikes XS part# 48-0884, but they are kind of proud of them. Have any members found a fix or a inexpensive replacement? The other option is JB Weld, but that's a little too drastic.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    If you do a search you should be able to find a few options for fixing them. I know I have seen a thread over the past couple years on several ways to fix them.
    • Montreux_Blue
      XS-XJ Guru (Deceased)
      • 1143
      http://cgi.ebay.com/BARBED-TUBE-TEE-...item5acf3457c0
      They sell similar brass tees at Home Depot.
      Famous Myspace quote:
        It would be cool to modify one of those brass T's with an o ring slot to fit our carbs.
        • Montreux_Blue
          • 1143
          These would work better.
          http://cgi.ebay.com/ebaymotors/Brass...ssoriesQ5fGear
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            Look at this thread; http://www.xs11.com/forum/showthread...&highlight=tee
            Maybe this will work.
            • Toolmaker Tim
              • 671
              I found the problem.....
              and it was me. When I reassembled the carb set I put the vent tee set from my spare carb set in the wrong place. That's why you are suppose to keep parts seperated. Oh well, but now I have a great idea for replacing the junky rubber overmolded tees. The ones from Mike's XS are pressed together, but I found a brass barb that is threaded on one end and made to hold a 1/4" ID hose on the other. I am going to try turning up a cross piece out of brass with O'ring grooves on the ends and tap a #10-32 hole in the middle for the barb. I'll let you know how it goes.
              1979XS1100SF
              Jardine 4in1
              Dunlop Elite 3's
              142.5 main jets
              45 pilot jets
              750/850 FD mod.
              XV 920 Needle Mod.
              • tadtl1
                • Mar 2010
                • 98
                • Auburn Mi
                z1 enterprises
                Hi,
                This vendor shows fuel tee s for other mikuni carbs, wonder if they will be any help to you. Ive talked on the phone to them re other things and found them quite helpful, could give that a try.
                http://www.z1enterprises.com/
                80 MNS , Georgefix pods , crossed fuel lines, no octy, inline filters, Daytona handlebar, custom seat, Hardley 19 muffs
