Front brakes that fit XS1100LH
  • B11
    • Apr 2004
    • 30
    • Vancouver Island Canada
    Anyone know of any other front brakes that fit the 81 XS1100 LH Midnight Special ? Need to find one fast ! Brian
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    what do you need?
    1980 LG
    1981 LH
    • B11
      • Apr 2004
      • 30
      Right Front brake caliper
      Desperately need right front brake caliper for 81 XS 11 LH ( Midnight Special ) ! Brian
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        Xj1100
        82-84 XJ1100 are the same
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • B11
          • Apr 2004
          • 30
          82-84 xj1100
          Thanks Axel ! Good to know ! Brian
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            Np
            One on ebay , kinda pricey though .
            Item number 110286917676
            Mine has play on the pivot and can be wiggled by hand but has worked well for years regardless . YMMV ...
            Usually they can be disassembled and cleaned even without a new seal and work well
            I guess thanks to the linked brake system - that right caliper gets a lot of use/wear
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
              Hi Brian,
              a caliper off an ordinary Special should fit right on.
              The calipers on XS750 & XS850 Specials look the same but I dunno if they are identical.
              • B11
                • Apr 2004
                • 30
                Front calipers that fit !
                My forks measure 43mm or 1 5/8" between the mounting holes. I think that is the crucial point. Anyone got one that measures 43mm ? Thanks to all who have responded ! Brian
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  uhh
                  I think regular Special calipers are different . The 81 LH had the same brake system as my XJ1100. Linked front left caliper with rear caliper with proportioning valve . Front right caliper on its own . Mounting holes are different IIRC .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • B11
                    • Apr 2004
                    • 30
                    front caliper
                    Saw the one on Evil Bay. Looks like a P.O.S. ! Was hoping someone had a working / better shape one ???? Brian ( Price is O.K. just want better condition !
                    Brian
                      Saw the one on Evil Bay. Looks like a P.O.S. ! Was hoping someone had a working / better shape one ???? ( Price is O.K. just want better condition! ) Brian
                      Hi Brian,
                      seems I know less than I thought about the '81 Midnight.
                      The E-bay offering looks to be the caliper for a Standard.
                      If it is indeed the right one for an '81 Midnight and you are OK with the price, you'd be amazed how well a thorough cleaning, a rebuild kit and a lick of paint can fix it up like new.
                        Those calipers are very hard to find. The 81 LH and the 82 XJ will interchange. It's possible that the 82 XV920 will also work, looks the same, but not 100% sure.
                          Yeah as those are very limited production pieces, finding one for sale in the condition your looking for is probably just a shade harder than finding a new never used 1963 split window coupe Corvette!
