Fork Diameter- 79 XS1100 Special Looking to use Clipon Bars
  • 79xs1100s
    • Aug 2009
    • 115
    Hey guys, ive searched this site, the uk site as well as Google and Yahoo! with no luck, im looking to put slip on bars on my special and I need to know the fork diammeter under the upper headlight mounting sleeve. Im looking for a size clipon to by (40mm, 55mm) etc, If someone has a quick response that would be awesome, Thanks
    XS11.Com resident Black Sheep
    • 8930
    The diameter of the fork upper tubes is 37MM, top to bottom, they have no taper under the headlight mounts.
    • psycoreefer
      • Feb 2008
      • 1557
      • Minden, NV
      be aware that clip-ons may hit the tank when you turn...I've not tried them but seen it mentioned.
      1979 xs1100 Special -
      My Bike:
      [link is broken]
      • bwilding_2000
        • 50
        • UTAH-SLC
        ry the ones off of the early cbr600 models (F1 or Hurricane) as they will fit the forks!
        • Eveready1100
          • 539
          • Childers, Queensland,Australia
          You could also check out the Kawasaki GPZ750 bars from '83 - 87. Same diameter and have adjustable angle (up / down)
          also, you could slide the fork tube up a bit through the top clamps and perch the bars on top of the triple clamp to help clear the tank.
