no start, Confused and frustrated
  • BigRed
    • Mar 2010
    • 265
    • Ottawa, Ontario, Canada
    Originally posted by dbeardslee
    I thought he was getting the reading between the feed wires and the high tension wires where there should be no continuity at all. According to Ivan that's an indication of a shorted coil
    Sorry, I misunderstood where you were getting your reading from. Hope I didn't confuse you. These guys know what they're talking about.
    Good luck!
    • psycoreefer
      • Feb 2008
      • 1557
      • Minden, NV
      Originally posted by Sgriger534
      Yes, i put the leads on the wire from the TCI where it is soldered onto on the other lead onto the high tension wire. It was very high resistance but as far as i know it should have been infinite, my reading was about 11 M ohms
      I really want to help you but this makes no sense to me, maybe its because its early and I haven't gotten my caffeine fix for the day yet..
      1979 xs1100 Special -
      My Bike:
      [link is broken]
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        For all practical purposes, 11,000,000 ohms is close enough to infinite.
        Ich habe dich nicht gefragt.
        • Sgriger534
          • 66
          • Farragut, IA
          #34
          no, it makes no since because it is early on my part. I put one of the leads onto the orange wire off of the tci where it is soldered onto the coil, and the other lead onto the high tension wire
          1978 XS1100
          • Sgriger534
            • 66
            • Farragut, IA
            #35
            Also does anybody know the part number for the accel coils
            1978 XS1100
            • dbeardslee
              • 4385
              • Maineville, OH
              #36
              You said you tested from the orange wire at the TCI? I think before you order coils, you might try that test at the coil, since what you're trying to determine is whether or not the coil is shorted. Running it through the rest of that wiring and connectors doesn't seem prudent. Who knows what other kind of 'leaks' you might have in the wiring that could produce a reading.
              • Sgriger534
                • 66
                • Farragut, IA
                #37
                I did test it at the coil, but is it werid for both coils to go out at the same time, now they are both stock coils i belive but i don't know if it is common for both to go out at the same time
                1978 XS1100
                • psycoreefer
                  • Feb 2008
                  • 1557
                  • Minden, NV
                  #38
                  I don't think that reading you got indicates a failed coil, at least not clearly enough that I'd want to spend 100+ on new coils.
                  My Bike:
                  [link is broken]
                  • randy
                    • Dec 2003
                    • 4521
                    #39
                    Not to beat a dead horse, but this is why I don't like using DMM's for this sort of work, they're too sensitive. For all you know, you could be reading through some damp insulation or your own body resistance.
                    I agree with Ivan, 11M is infinite as it applies to these circuits. You should be testing between the high tension (spark plug) wires to test the secondary side of the coils, then between Orange and Red/White for one primary and then Gray and Red/White for the other primary.
                    Do the primary tests with both leads disconnected from the TCI, otherwise your readings could be wacky.
                    • Sgriger534
                      • 66
                      • Farragut, IA
                      #40
                      i think also today i am going to pick up a anolog multimeter so i can actually do the test on the tci right.
                      1978 XS1100
