Re: Float setting. I am now wondering the float height for my carbs- I wanted to verify the measurement... I saw it somewhere, now can't locate it. (1980 sg). I set them at 23mm as I remember (w/o the gasket- off the base), but want to check them with the tubes that are hooked into the bowl drain plugs, as in the maint section on carbs...(had some fuel go into the airbox today after it was shut down- mainly due to me- I left the petcock on prime by mistake, but it still should have shut off at the float, and it's running too fat).
What thread size is the plug? My book is not accessible at the moment. I think I'm still fat...(yeh, the carbs are too
The setting for the height with the tubes shows the level at the base of the screw that hold the bowl on- correct? Thx
)The setting for the height with the tubes shows the level at the base of the screw that hold the bowl on- correct? Thx
