i was riding then....
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    the xs decided to just turn off....checked the fuses there ok the battery is in tight and is good.....any idea where to start?
    1980 gs1000g "stock"
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Check the main fuse behind the left side cover just left of the battery. It's a 30 amp if you don't already know.
    BDF Special
      Do you still have the old crappy glass fuses? If so get rid of them. They were causing me all kinds of unknown trouble!
      • mro
        • 4276
        • Hayward, California
        Besides the main fuse,
        tip over switch
        kill switch on the right control
        pick-up coil wires
        can also cause the engine to die at very inopportune times.
        mro
        The keyed switch can be a problem, but I've yet to have it happen to me.
          Several folks have described those same conditions with the key switch being the culprit.
          I think on the 79 models, the main fuse is in the fuse block under the right side cover.
          • MindWebs
            • May 2009
            • 431
            • Baldwin, WI
            YUP, it sucks been there done that. 79sf
            ATC Fuse block!!
            and all those glass issues go away.
            (assuming all the connecters have been cleaned and die-electric greased.)
            • lee_dutcher
              • Apr 2009
              • 822
              • mason city iowa
              Originally posted by DGXSER
              Several folks have described those same conditions with the key switch being the culprit. I think on the 79 models, the main fuse is in the fuse block under the right side cover.
              no glass fuses the po put in line fuses in for me....but it seems to have no power geting to the bike...but sometimes if i sit on it and gently hit the right side of the bike the nutraul light and stuff comes on for a second then it stops....it wont crank or anything..
              • GARTHXS
                • 1631
                • Seattle
                Do you have a gel battery if so they will die suddenly like that
                91 kwaka kz1000p
                Stock
                ( Insert clever quote here )
                  If you lost everything completely, I would say it is either the key switch or fuse. If tapping the right side like that shows signs of life, then I would lean toward fuse.
                  If it were me chasing this down, I'd pull the right side cover, turn on the key and see where you have power going into your fuses (should be all of them) and then again, where you have power coming out. With the loose hanging fuses, I would think they could get to swinging in there or at least vibrate a bit and possibly cause a poor connection or fatigue a connector. Just my thoughts.
                    • 2117
                    I don't know if your bike has the tip over switch but my friend had one that suddenly slipped from the mount and the bike died.
                    • MrOzz
                      • Aug 2008
                      • 782
                      • Massachusetts
                      Mine did that once. I found the ground on the battery was a little loose. I tightened back up and all was well. JAT
                      1980 XS 1100SG
                      Dyna 3 Ohm Hi Output Coils
                      Pod Filters
                      DynoJet Kit
                      T.C.'s Fuse Block
                      V-Max Auto CCT
                      • dbeardslee
                        • 4385
                        • Maineville, OH
                        I just had the same problem with Betsy last week. It wound up being in the handlebar switch, but not on the kill switch half - it was evidently the starter switch. Anyway, cleaning that side of the switch assembly got me back on the road. Put a jumper on the starter solenoid from the hot to the blob of solder with the red/wht wire, and hit the starter. If it starts that tells you it's somewhere in the red/wht. If you want to check continuity the red/wht runs from the fuse block, to the handlebar switch - handlebar switch to ballast resistor - ballast resistor to coil 'Y' connector.
                        • mstic2000
                          • Aug 2008
                          • 574
                          • Saginaw, Mi
                          Ya, that happened to me once. After setting there for a half hour fiddle f'ing around with wires. I found I had accidently somehow hit the kill switch.
                          My 1978 http://img.photobucket.com/albums/v518/mstic2000/xs.jpg
                          • lee_dutcher
                            • Apr 2009
                            • 822
                            • mason city iowa
                            i know the fuses r good i checked the twice.pretty sure i dont have a kick stand switch well if there was there isnt one there anymore.but if the kill switch was hit the bike still should light up. what would cause a key switch to go bad? guess im going to start with some electrical cleaning
                              Corrosion. Check the connector for the ign. switch in the headlight bucket, they tend to melt. The ign. switch can be taken apart and cleaned if needed, no need to replace it.
