shocking question
  • shocking question
    Does anybody out there know if rear shocks from an 82XJ will fit a 78XS?
    buffalo
    80 XS1100SG
    I don't have your answer, but if you go to parts.com, or any of the online parts sites that use the micro-fiche, you can look-up the part # for both bikes to see if they match.
    Mike
    1980 SG "Angus"
      Or go to www.progressivesuspension.com and see if they list the same applications.
      Gary Granger
        here ya go
        Name
        412 Dual/12.5
        Description
        412 SERIES DUAL
        SHOCK ASSEMBLIES
        Manufacturer
        Progressive Suspension
        Type
        Shock Absorber
        This Part Fits These Models:
        Yamaha 1100
        XJ1100 Maxim
        1982-1982
        Yamaha
        1100
        XS1100
        1978-1981
        Yamaha
        1100
        XS1100L Midnight Special
        1980-1981
        Yamaha
        1100
        XS1100S Special
        1979-1981
        Seamus Ó hUrmholtaigh
        Niimi Moozhwaagan
        and SOXS
        2008 Nomad "Deja Buick'
          The XJ stock factory shocks are air adjustable. The fitting is on the left-side rear shock. Both shocks are tied tgether through a pipe so pressure is balanced. Shocks will fit the XS but you should get the plumbing that goes with them. If you are talking aftermarket units, yes the XJ and XS shocks are interchangeable. They are not air adjustable, so you need to remove the plumbing when you remove the stock shocks.
          Item #23 is balance tube. Air fitting parts are #16, 17, and 18.
          FWIW, I run the stock shocks at 24 - 28 PSI.
          Jerry Fields
          '82 XJ 'Sojourn'
          '06 Concours
          My Galleries Page.
          My Blog Page.
            Buffalo,
            I put a set of Air Shocks off a 82 XJ on my 81 XS. I was trying to get a lower seat for a short legged man. I let all the air out of the shocks and gained a little but not enough. I have since installed a set of 11" Progressive 412's. That was the ticket for me. Getting back to your question, yes, I think they will fit, looking at the 78 vrs the 81. Seems to be the same set up.
            JTodd
            81' XS1100LH
            I bought it for a bargain, now it is a prize.
