Does anybody out there know if rear shocks from an 82XJ will fit a 78XS?
shocking question
Or go to www.progressivesuspension.com and see if they list the same applications.Gary Granger
2013 Suzuki DR650SE, 2009 Kawasaki Concours 1400, 2003 Aprilia RSV Mille TuonoComment
here ya go
Name
412 Dual/12.5
Description
412 SERIES DUAL
SHOCK ASSEMBLIES
Manufacturer
Progressive Suspension
Type
Shock Absorber
This Part Fits These Models:
Yamaha 1100
XJ1100 Maxim
1982-1982
Yamaha
1100
XS1100
1978-1981
Yamaha
1100
XS1100L Midnight Special
1980-1981
Yamaha
1100
XS1100S Special
1979-1981Seamus Ó hUrmholtaigh
Niimi Moozhwaagan
NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
Any connection between your reality and mine is purely coincidental.
Member of "FOXS-11" (Former Owner of XS-11)
and SOXS
2008 Nomad "Deja Buick'Comment
The XJ stock factory shocks are air adjustable. The fitting is on the left-side rear shock. Both shocks are tied tgether through a pipe so pressure is balanced. Shocks will fit the XS but you should get the plumbing that goes with them. If you are talking aftermarket units, yes the XJ and XS shocks are interchangeable. They are not air adjustable, so you need to remove the plumbing when you remove the stock shocks.
Item #23 is balance tube. Air fitting parts are #16, 17, and 18.
FWIW, I run the stock shocks at 24 - 28 PSI.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
Buffalo,
I put a set of Air Shocks off a 82 XJ on my 81 XS. I was trying to get a lower seat for a short legged man. I let all the air out of the shocks and gained a little but not enough. I have since installed a set of 11" Progressive 412's. That was the ticket for me. Getting back to your question, yes, I think they will fit, looking at the 78 vrs the 81. Seems to be the same set up.
JTodd81' XS1100LH
I bought it for a bargain, now it is a prize.Comment
