Ring's
  • mack
    • 2411
    • Ontario, Canada
    Ring's
    I was hoping my numbers would have improved by now but no luck. I need rings. I really don't want to go to a bigger bore kit as I want to keep him stock. Anyway a couple questions. One. what damage am I doing by riding with poor compression; and, TWo Can you still get stock rings?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    New rings are still available, although a used motor is probably cheaper. $50 a set per piston...
    • petejw
      • 2269
      • sydney australia
      if the engines quiet, you wouldnt be doing any damage,
      if you can here the piston slapping, that could be a different
      story, have you tried adjusting your valves?
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • Tdog
        • Apr 2006
        • 67
        • Bradford Ontario Canada
        rings
        Here's the piston ring thread for more info.
        Regards,
        T
        '81 H
