well guys thanks to you and your help i did a sucsesfull 1,2 gear fix
clutch install.
i did the first test run WOW great power.
this bike had 4 into 1 looks like kirker its all chrome, and k&n pods.
i also did the rick carb cleaning- bench sinced, new plugs new middle and rear drive oil. tranny oil.
bike idles great but if i hit the throtel hard in wants to bog- from 1000-2000 rpm so it just kinda bogs for a sec then bam takes off and everything is good from there, so its just off the line.
i have not sinced the carbs, i cant remember the jets size i wanna say like 120-125
and 45-50
i know my xj650 came with 110-40 i think
so can anyone tell me what jet size i should be running with 4-1 and pods?
if they are good i gues check float height might need mor gas?
is it the pilot or main that controles low end? if i remember its the needle that does mid?
i almost have this thing running, i did a 12 mile test ran great except off line if i get on it, also the oil warning comes on and off, i heard thats a common prob, i did notice the oil is a little milky like condensation i cleand the tranny pan and blew it out, i think i will run it for a wile then change oil again
any help would be great. thanks
clutch install.
and 45-50
(Sold back to Maximan)
